Car Stutters, WTF can be wrong? Help Plz....
Old Jul 21, 2006 | 09:09 PM
D21X's Avatar
Default Car Stutters, WTF can be wrong? Help Plz....
Motor: d16z6 head, SOHC ZC block, P28 ecu, I/H/E
When I start my car up in the morning and start driving, the engine feels like its dying when I start to drive the car, feels like my fuel is getting cut or ignition. The car won't die, but it'll just lose power, lots of it.
On the highway around 70-80mph, it loses power, engine will spin, but no power will be made. fuel or ignition cuts out and then cuts back again, this is with partial throttle. When i put my foot all the way to the throttle, it'll keep going and won't die, unless i go back to partial throttle.
I have just replaced my cap and rotor, engine has about 130k miles. Fuel filter was also changed recently. I did swap out my 4 injectors for another set of 4 injectors.
I still need to swap out main relays. Maybe try another fuel pump....
Let me know what you guys think could be wrong...
Old Jul 22, 2006 | 06:14 PM
D21X's Avatar
Default Re: Car Stutters, WTF can be wrong? Help Plz.... (D21X)
guess no one has ever had this happen...
Old Jul 22, 2006 | 06:55 PM
commotion's Avatar
check ur timing
Old Jul 22, 2006 | 09:33 PM
D21X's Avatar
Default Re: Car Stutters, WTF can be wrong? Help Plz.... (commotion)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by commotion &raquo;</TD></TR><TR><TD CLASS="quote">check ur timing</TD></TR></TABLE>
timing is good, 16 degrees.....
Old Jul 22, 2006 | 09:40 PM
Syndacate's Avatar
& ur TPS?
Old Jul 23, 2006 | 06:27 AM
D21X's Avatar
Default Re: (Syndacate)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Syndacate &raquo;</TD></TR><TR><TD CLASS="quote">& ur TPS?</TD></TR></TABLE>
I am going to switch my TPS today to see if that might be the problem.....
Any other suggestions?
Old Jul 23, 2006 | 06:28 AM
D21X's Avatar
Default Re: (D21X)
Oh and I did swap out my main relay with a working one, and that did not solve the problem...
Old Jul 23, 2006 | 06:56 AM
jibs's Avatar
Default Re: (D21X)
I think sometimes a dying ignition module can cause your symptoms. Happened to me on a non-honda car of mine once. Easy to test with a volt ohm meter or Autozone will test it for you
Corksil
13
Oct 8, 2011 09:10 PM
deanBUG
13
Apr 22, 2009 10:33 AM
MPF_supra
Jul 22, 2007 10:17 PM
P-DuBB
Apr 12, 2005 08:44 PM
AC2i0v0i0c
Oct 18, 2004 11:31 AM
