problems
i just bought a 1990 crx si and it over heats but what i was wondering is the guy that owned it before me took the radiator fan and fan motor out of it and would that make it overheat as easy as it does? thanks
Modified by phairse at 6:51 PM 7/21/2006
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by phairse »</TD></TR><TR><TD CLASS="quote">i just bought a 1990 crx si and it over heats but what i was wondering is the guy that owned it before me took the radiator fan and fan motor out of it and would that make it overheat as easy as it does? thanks</TD></TR></TABLE>yes
if there is no fan it would only overheat when stopped, if you are driving the air would be sufficient to cool properly, if it overheats when driving its probably your thermostat get a new one from honda
well there seems to be another problem. i guess the car has been sitting there for 2 weeks with a dead battery and me and a friend jumped it and i thought it would charge the battery but after runing it for awhile and shutting it off it when u turn it back on the start up lights are very dim and the altenator and battery were new like 2 months ago
If a battery sits dead for to long, it can go bad. Even in 2 months. Check your voltage while the car is running, then check it when the car is off. When it is running, it should be at 13.5 to 14.50 volts. When it is not running it should be around 12 volts.
well since i finally got my cast off from breaking my hand i think this weekend i am going to take out and tear down my engine and put a couple new things in it like a new head gasket, rings, valve cover gasket, aftermarket pullys
Joey.
Apr 20, 2006 03:41 PM
mike93eh
Mar 26, 2005 03:04 PM
