OBD0 b16 Code help
Old Jul 21, 2006 | 04:04 PM
Touge Tuning's Avatar
Default OBD0 b16 Code help
My buddy has an obd0 b16 in his 1990 integra and it throws 2 codes (blinking LED on ECU). The first is code 9, I cant seem to find anything pertaining to a code 9 so if anyone could help me with that it would be appreciated. The other is code 23 which to my understanding is for the Knock Sensor, im not sure if he has wired it up as its an LS teg so ill have to check that but wanted to make sure its the right code first.
Also he seems to be having a temperature problem as the needle never goes above 1/4 way on the gauge. Is this normal for DA tegs or is it most likely a gauge or sensor problem?
Old Jul 21, 2006 | 07:52 PM
Jose-aka-Pedro's Avatar
Default Re: OBD0 b16 Code help (Stealth1)
Ok here ya go man,
check it out.
ECU codes for OBD0 B16
http://www.integra.orcon.net.nz/ecucodes
9) CYP (Cylinder) - Defective circuit or unplugged/ Defective sensor
23) Knock Sensor - Defective circuit or unplugged / Defective sensor
Good luck with the knock sensor, its a biatch, You have to wire it with special wire,
I'm working on it right now, Only having the knock sensor code
will put the ECU in limph mode, and you cant drive it,
1) Primary oxygen sensor- Defective circuit or unplugged/ Defective sensor
2) Oxygen sensor "B" - Defective circiut or unplugged/ Defective sensor
3) MAP (Manifold Absolute Pressure) Sensor - Defective circuit or unplugged/ Sensor
4) CKP (Crankshaft Position Sensor) - Defective circuit or unplugged/ Defective sensor
5) MAP (Manifold Absolute Pressure) sensor -Mechanical problem/ Disconnected piping
6) ECT ( Engine Coolant Temperature) Sensor- Defective circuit or unplugged/ Sensor
7) TP (Throttle Position) Sensor -Defective circuit or unplugged/ Defective sensor
8) TDC (Top Dead Centre) Sensor -Defective circuit or unplugged/ Defective sensor
10) IAT (Intake Air Temperature)sensor- Defective circuit or unplugged/Defective sensor
12) EGR (Exhaust Gas Recirculation) -Defective circuit or unplugged/ Defective sensor
13) Atmospheric Pressure Sensor - Defective circuit or unplugged/ Defective sensor
14) IAC (Intake Air Control) Valve- Defective circuit or unplugged / Defective sensor
15) Ignition Output Signal - Missing or defective ignition output signal
16) Fuel Injector System - Defective circuit or unplugged/ Defective fuel injector
17) VSS (Vehicle Speed Sensor) - Defective circuit or unplugged/ Defective sensor
19) Automatic transmission lockup control Solenoid Valve- Defective circuit or unplugged/ Defective solenoid. A/T Only.
20) Electronic Load Detector - Defective circuit or unplugged/ Defective sensor
21) VTEC Solenoid Valve- Defective circuit or unplugged/ Defective solenoid
22) VTEC Oil Pressure Switch - Defective circuit or unplugged/ Defective switch
30) Automatic Transmission Signal- Defective circuit or unplugged/ Defective sensor
31) Automatic Transmission Signal "B"- Defective circuit or unplugged/ Defective sensor
41) Primary Oxygen Sensor Heater- Circiut malfunction
43) Fuel Supply System - Defective or malfunctioning Fuel Supply Sytem
45) System too lean or too rich - Malfunction in the fuel monitoring systems
48) LAF (Lean Air Fuel) sensor - Defective circuit or unplugged / Defective sensor
54) CKF (Crankshaft Speed Fluctuation) sensor- Defective circuit or unplugged / Defective sensor
61) Primary Oxygen sensor circuit- High/ Low Voltage, Or slow response
63) Secondary Oxygen Sensor circuit- High/ Low Voltage, Or slow response
67) Catalyst System Efficiency Below Threshold- Malfunctioning catalyst system
70) Automatic Transmission - Malfunction with Automatic Transmission Controls
71-74) Random misfire in Cylinders 1-4- Condition present Creating Misfire
80) EGR (Exhaust Gas Recirculation) Insufficient Flow Detected
86) ECT (Engine Coolant Temperature) Circuir Range / Performance Problem
90) Evaporative Emissions Contrlo System - Leak Detected In Fuel Tank Area
91) Fuel Tank Pressure Sensor- Low Input
92) Evaporative Emission Control System Control System- Insufficient Purge Flow
Old Jul 21, 2006 | 08:06 PM
Default Re: OBD0 b16 Code help (Jose-aka-Pedro)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jose-aka-Pedro &raquo;</TD></TR><TR><TD CLASS="quote">Ok here ya go man,
check it out.
92) Evaporative Emission Control System Control System- Insufficient Purge Flow</TD></TR></TABLE>
Yeah i figured that code should put the car in limp mode but it runs ok and doesnt have a low rev limit or anything. Any idea on troubleshooting code 9?
Old Jul 21, 2006 | 09:21 PM
SiR_Injected's Avatar
I GOT CODE 23 (KNOCK) car is running fine its not in limp mode but what kind of special wire do i need ???
also i got CODE 17 VSS speed sensor no idea which one to look for since it showing 2 front 2 rear
Old Jul 21, 2006 | 09:39 PM
vss is on top of the tranny near the firewall. as far as the special wire mentioned above i believe he just means you need to use shielded wire so as to prevent "noise" from entering the signal
Old Jul 11, 2016 | 06:18 PM
f22b2's Avatar
What up guy's
I have a 1990 acura integra gs with jdm b16a and vtec not working because
Over 4000 rpms check engine get on
I see code 23 knock sensor
But I replaced and wire are good
I just find out that oxygen sensor go on cat back it's not connected last owner cut the wire
IDK if that make the the knock sensor show on the ecu or
I will have too replace the ecu
On the way people tell me probably I will have too replace.
EF_FEVER
Feb 22, 2007 12:32 PM
StupidSlowRSX
16
Oct 5, 2004 04:26 PM
noob23
Aug 27, 2004 03:59 PM
R@mon
Jan 7, 2003 02:28 PM
hybrid901
May 1, 2002 12:59 PM
