anyone tried a VNT turbo
garrett has made some for the aftermarket scene. its old stuff, depending on the size turbo you buy you dont even need to run a wastegate anymore. basically it adjusts so you can have quick boost on the low end and it'll open up when you get in the high rpm's.
that looks like the turbos that are in the new ford 6 liter diesels ford calls it vgt (variable geometry turbo) having problems with them the fins are sticking and also garret makes them
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Flashmn »</TD></TR><TR><TD CLASS="quote">supposedly they wont last through gasoline engine EGT's.</TD></TR></TABLE>Word was that the new 2.3 Turbo was going to run VNT
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rebo0t »</TD></TR><TR><TD CLASS="quote">the new 911's run them. the new turbo honda's run one like it. instead of the rear blades being adjustable, its the front compression side that does it.</TD></TR></TABLE>
Yea the new 911 use them. 450 ft/lbs of torque at 1900rpm
505 ft/lbs with the "sport mode" on @ 1900 rpm's....From a friggin 3.6 liter!
Its amazing! Ive driven one of the new turbos and its sick. Tried to price one out but the parts dept. doesnt have it in there system yet...
Imagine...Built B18C reaching peak torque @ 2-3k and carrying it to or near redline! Makes me smile!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PyroProblem »</TD></TR><TR><TD CLASS="quote">505 ft/lbs with the "sport mode" on @ 1900 rpm's....From a friggin 3.6 liter!
*sheds a tear*
*sheds a tear*
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DRAGLS »</TD></TR><TR><TD CLASS="quote">
that is absolutely nasty
wonder how many WHP they are good for?
i know you could not overboost them too much cause they are tempermental (spelling) to heat........bad
</TD></TR></TABLE>that is absolutely nasty
From what ive been told, the EGT's from gasoline engines were too high for the materials in the VGT to hold up.Supposedly as technology is advancing, they have gotten it to work...
Chrysler used this type of turbo way back in the day, but were unsuccessful in perfecting it. I believe Borg Warner is now producing the turbos for Porsche.
On the 911, there is no wastegate. Boost is regulated by controlling the exhaust fins...
I suppose since the 3.6L can make 500 ft/lbs below 2k, a 1.8L could (theoretically) make ~250 ft/lbs at about the same rpm range
WHP on the 911 turbo is probably around the 400 range. Theyre rated @ 470(ish)crank hp but theyre also AWD...
I have also looked into these...the ones that are readily available (old turbo dodges) are too small so it doesnt really "shine" and aparantly the design was never perfected. hopefully someday we will figure out a way to eliminate lag. good to see advances being made. that porsche is SICK too
sorry but what you just said its totally wrong
research before spreading the wrong gossip!
its the turbine side that changes the flow not the compressor
ahhh sorry not spreading gossip. i remember somebody doing the cold side and when i read that article they it said "develop an entirely new turbocharger w/ aishin". VNT's are nothing new so i thought it was honda that did the cold side. nontheless, there is a company using the cold side
