DA horn not working
I requested a short story for a title.
ok heres the story. i ordered this alarm kit off the internet. the alarm works great but the diagram the guy gave me was wrong and it said wire the constant 12 volts to the white wire with a green stripe (which i later found was part of the horn circuit) but for some reason it said ignition wire. well in the process i touched the wire on a peice of metal and it sparked a little bit, usually i have the battery disconnected but for this little bit it was hoooked up. After that there was nothing. the constant 12 volts to it was gone. I ended up finding the real igniton wire and went from there. After i got the alarm and locks hooked up and working i tested everything and all but the horn works. the fuse is still good and when i was putting the ignition cover back on the clip slipped off and hit the horn behind the wheel and it worked.
but my question now is there a realy somewhere that might have blown? since everthing else is good please help me out
uhhRay
Mar 26, 2012 09:04 PM
cxSHOE
Audio / Security / Video
28
Mar 15, 2004 05:24 AM
phathodna35456
May 16, 2003 04:47 AM
