crankshaft pulley.
Old Jul 20, 2006 | 03:26 PM
soulforce's Avatar
Default crankshaft pulley.
Im in the process of removing my head and Im trying to remove the crankshaft pulley so i can remove the lover timeing belt cover to get to the belt tensioner. MY PROBLEM IS: when I try to loosen the crankshaft bolt the crankshaft obviously moves. I wanted to know how to stop the crankshaft from turning. Do I need a special tool for this?
Old Jul 20, 2006 | 03:38 PM
soulforce's Avatar
Old Jul 20, 2006 | 04:08 PM
fms1day's Avatar
Default Re: (soulforce)
motor in the car or off the car?
Old Jul 20, 2006 | 05:39 PM
markivy's Avatar
Default Re: crankshaft pulley. (soulforce)
If the del Sol is similar to the 92 Civic, you can remove the access cover to the flywheel and wedge a chisel or similar hardened steel object between the flywheel and the casing that surrounds it. Be careful not to damage the teeth that the starter motor engages. If there is no access plate to the flywheel on the del Sol, you might be able to remove the starter and arrest the flywheel there. The crankshaft pulley bolt is one of the hardest to remove that I have encountered. Good luck.
Old Jul 20, 2006 | 05:44 PM
philosofy1's Avatar
Default Re: crankshaft pulley. (markivy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by markivy &raquo;</TD></TR><TR><TD CLASS="quote">If the del Sol is similar to the 92 Civic, you can remove the access cover to the flywheel and wedge a chisel or similar hardened steel object between the flywheel and the casing that surrounds it. Be careful not to damage the teeth that the starter motor engages. If there is no access plate to the flywheel on the del Sol, you might be able to remove the starter and arrest the flywheel there. The crankshaft pulley bolt is one of the hardest to remove that I have encountered. Good luck.</TD></TR></TABLE>
that's what i was thinking.
Old Jul 20, 2006 | 09:44 PM
soulforce's Avatar
The motor is in the car. thanks for the idea. ill try that
Old Jul 20, 2006 | 10:16 PM
.Kevin.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by soulforce &raquo;</TD></TR><TR><TD CLASS="quote">The motor is in the car. thanks for the idea. ill try that
No no you shouldnt. Then you will be removing the clutch and flywheel because you brook a tooth.
First try putting it in gear and stepping on the brakes. If that does not work get a pully tool. If you have air tools this also should not be a problem and it should just zip right off.
Old Jul 20, 2006 | 10:17 PM
ddd4114's Avatar
yep, he hit the nail on the head
Old Jul 20, 2006 | 10:37 PM
.Kevin.'s Avatar
Default Re: crankshaft pulley. (ddd4114)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ddd4114 &raquo;</TD></TR><TR><TD CLASS="quote">
yep, he hit the nail on the head</TD></TR></TABLE>
do you guys not understand how easy it is to break a tooth? Just do it the correct way and get the tool or use air tools.
Old Jul 20, 2006 | 11:32 PM
Evs-One's Avatar
Solbros Owns Me
Default Re: crankshaft pulley. (Ep_Kevin)
no, do it the correct way and don't touch the crank pulley if you're just pulling the head. Look at the lower cover and you'll see a rubber cap below the engine mount. Rmove said plug and there is the 14mm tensioner bolt. Loosen, and slide belt off cam and remove head. Honda thinks of things like this.
Old Jul 20, 2006 | 11:39 PM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: crankshaft pulley. (Evs-One)
Use a strap or chain wrench and a breaker bar. Wrap the chain/strap wrench around the pully, and get a large breaker bar and impact socket.
I've actually had that method work when an impact gun hasn't.
Old Jul 20, 2006 | 11:50 PM
.Kevin.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Evs-One &raquo;</TD></TR><TR><TD CLASS="quote">no, do it the correct way and don't touch the crank pulley if you're just pulling the head. Look at the lower cover and you'll see a rubber cap below the engine mount. Rmove said plug and there is the 14mm tensioner bolt. Loosen, and slide belt off cam and remove head. Honda thinks of things like this.</TD></TR></TABLE>
lol this guy is correct I guess I could have told you that in the first place. Do it this way unless you plan on replacing the timing belt at the same time or the water pump.
Old Jul 21, 2006 | 10:58 AM
ddd4114's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ep_Kevin &raquo;</TD></TR><TR><TD CLASS="quote">do you guys not understand how easy it is to break a tooth?</TD></TR></TABLE>
Who says I'm using the teeth?
However, I will admit that I skimmed through the thread when I first read it, and Evs-One definitely has the best method; no need to remove the pulley in the first place.
Old Jul 21, 2006 | 01:14 PM
soulforce's Avatar
ya i loosend that bolt but how am i supposed to slide the belt tensioner to create slack if the lower cover is on. It ain helpin just to loosen the bolt.
Old Jul 21, 2006 | 02:15 PM
soulforce's Avatar
anyone?
Old Jul 21, 2006 | 04:23 PM
Raggedyman's Avatar
Just cracking that bolt loose should cause the spring to release and let you get some slack in that belt. Your tensioner might be stuck somehow. I was able to slide my belt off the the cam pulley with just a small bit of slack and even put it back on when I did a head swap. Keep at it and good luck!
On a side note, have you guys tried this: http://www.amazon.com/gp/produ...28013
I bought one to pull a crank bolt that I couldn't budge with an air impact and it worked great! Had 2 cheater bars....one on the tool and the other on a breaker bar with the socket.
Old Jul 21, 2006 | 04:27 PM
SavEM1's Avatar
I'd use a chain tool, but supposedly those over time mess up pulleys but iono
Old Jul 21, 2006 | 04:29 PM
jtchinoy's Avatar
Personally, I'd just remove the valve cover, slide the belt off the cams, remove the head, deal with putting the timing belt back on after you're done w/ the head. If you have a DOHC, I don't know if you can do it, but I hate dealing w/ my tensioner so that's what I do when I have to remove the belt on my y8.
laloquera916
23
Jan 21, 2020 02:17 PM
Dutch_commando
11
Jun 24, 2017 08:26 AM
garrett2601
10
Jun 24, 2009 12:56 AM
bdubnyc
Oct 2, 2007 07:17 PM
altoid
Jun 27, 2003 12:34 AM
