Honda S2000 Honda S2000
HIgh Flow Cat?
Old Jul 20, 2006 | 02:43 PM
EJ8 GSR-T's Avatar
Default HIgh Flow Cat?
I am just wondering if anyone makes a high-flow cat for the s2000? Its supercharged but somehow the stock cat had......somewhat of a meltdown. I know i could just put a straightpipe on but i dont want the noise and i need to be able to pass emissions.
Old Jul 20, 2006 | 03:32 PM
LAS2K's Avatar
Default Re: HIgh Flow Cat? (EJ8 GSR-T)
you will never pass emissions. find a guy that does smog tests and bribe him.
berk test pipe and T1R test pipe both work.
Old Jul 20, 2006 | 04:42 PM
revhi's Avatar
Straight pipe, it wont really add much noise at all. i gained from 12-20whp midrange with one.
Old Jul 20, 2006 | 05:09 PM
EJ8 GSR-T's Avatar
Default Re: HIgh Flow Cat? (LAS2K)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LAS2K &raquo;</TD></TR><TR><TD CLASS="quote">you will never pass emissions. find a guy that does smog tests and bribe him.
why would i never pass?
Old Jul 20, 2006 | 06:04 PM
EJ8 GSR-T's Avatar
http://www.autocarparts.com/part/list/115/
why would this not be good for boost?
Modified by EJ8 GSR-T at 10:39 PM 7/20/2006
Old Jul 20, 2006 | 09:17 PM
EJ8 GSR-T's Avatar
Old Jul 21, 2006 | 12:40 AM
Secret Squirrel's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EJ8 GSR-T &raquo;</TD></TR><TR><TD CLASS="quote">
why would i never pass?</TD></TR></TABLE>
If you are using a hi-flow cat, you might still be able to pass emisions. I had an Integra that passed with one. Although if somebody knows what they are looking for, they might not pass it on the visual.
Test Pipe you will definatly not pass, since you won't have a cat on the car...
No reason why it would be bad in an FI setup.
Old Jul 21, 2006 | 12:53 AM
Agent Zero's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EJ8 GSR-T &raquo;</TD></TR><TR><TD CLASS="quote">I am just wondering if anyone makes a high-flow cat for the s2000? Its supercharged but somehow the stock cat had......somewhat of a meltdown. I know i could just put a straightpipe on but i dont want the noise and i need to be able to pass emissions.</TD></TR></TABLE>
If I remember correctly they don't hook up the sniffer to newer cars. (in Texas) They only look at the safety features and drive it for a minute. (to check brakes and whatnot) They hook up to your ECU and check for codes. You should be fine as long as your car doesn't sound like *** or doesn't throw any codes. For example.. I went with a friend to get his truck inspected, it took all of about 10 minutes. No sniffer and they just checked the gas cap, turn signals, brakes, headlights... well you get the idea. Hope that helps..
Old Jul 23, 2006 | 02:30 PM
philadd's Avatar
Default Re: HIgh Flow Cat? (redsihatchback)
In Houston (Spring included), they just plug in to the OBD II port.
Old Jul 23, 2006 | 02:47 PM
EJ8 GSR-T's Avatar
Default Re: HIgh Flow Cat? (philadd)
yeah...i just got one of those random tech high flow cats
Old Jul 23, 2006 | 09:32 PM
philadd's Avatar
Some people have said that the stock S2000 cat flows as well or better than aftermarket high-flow cats. I personally don't have any experience with this, so...
As long as you don't have a CEL, you should pass just fine.
jimmy o.
10
Nov 3, 2008 04:20 PM
Vtecattack
Mar 14, 2006 02:24 PM
caslmenow
Sep 11, 2002 04:51 PM
Blue-Civic-Hybrid
12
Apr 11, 2002 04:39 PM
Mr. Vapor
Oct 17, 2001 08:35 AM
