Engine Overheating- what should I check
Old Jul 19, 2006 | 08:51 PM
Maxpower350's Avatar
Default Engine Overheating- what should I check
I serchedjust making sure now
I plan on buying a new thermasta tommarow, and a fan switch because mines doesnt kick on for ****, but other then what do i check. I
m going to flush out the engine too tommarow with the thermastat out.
What do i check to make my car not overheat anymore.
Old Jul 20, 2006 | 07:36 AM
Hyaboosta's Avatar
Default Re: Engine Overheating- what should I check (Maxpower350)
flush the cooling system and be sure there is no air in the system and that you are using the proper mix of coolant to water. you can check the resistance on the thermostat to be sure that it is within spec and working properly. or you could have a restriction in the cooling system.
Old Jul 20, 2006 | 11:52 AM
Crazydave's Avatar
Default Re: Engine Overheating- what should I check (Hyaboosta)
https://honda-tech.com/zerothread?id=1671350
read this post there are some good ideas here..
opg5009
Jun 11, 2007 08:40 AM
floatfisher
May 19, 2007 04:20 AM
DRKSol
Jul 6, 2003 02:59 PM
[626] Crazy Rawb
Oct 15, 2002 07:41 PM
