LSD tranny
Old Jul 19, 2006 | 07:25 AM
dragaholic's Avatar
Default LSD tranny
Hi guys,
Is it possible to tell if a tranny is lsd or not without removing the axles?
I heard that if you spin one tyre and the other spins in the same direction then you have an lsd tranny. If it spins in the opposite direction its an open diff.
Can someone confirm this.
Old Jul 19, 2006 | 07:27 AM
-Gary-'s Avatar
Default Re: LSD tranny (dragaholic)
I'd like to know this too.
Old Jul 19, 2006 | 08:03 AM
JDM B16A's Avatar
Default Re: LSD tranny (-Gary-)
No way of telling if a tranny is equipped with LSD. You have to the axles off.
Old Jul 19, 2006 | 08:04 AM
Syndacate's Avatar
Default Re: LSD tranny (JDM B16A)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM B16A &raquo;</TD></TR><TR><TD CLASS="quote">No way of telling if a tranny is equipped with LSD. You have to the axles off. </TD></TR></TABLE>
It says it right on the tranny, by the serial # or vin # or whatever, it says "LSD" - if not then it's not LSD
Old Jul 19, 2006 | 08:05 AM
SkoundrelUSA's Avatar
cute little bastard
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dragaholic &raquo;</TD></TR><TR><TD CLASS="quote">Hi guys,
Not always true. My stock Y21 w/ LSD on my car spins in the same direction. But I've heard that ITR trannys don't do this and they have LSD
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Syndacate &raquo;</TD></TR><TR><TD CLASS="quote">
It says it right on the tranny, by the serial # or vin # or whatever, it says "LSD" - if not then it's not LSD</TD></TR></TABLE>
Not true either. My Y21 doesn't say anything but I looked through the differential, no rod
Old Jul 19, 2006 | 08:31 AM
philosofy1's Avatar
Default Re: LSD tranny (Syndacate)
not true. when i did my swap my tranny(JDM B16A) had no LSD stamp nor the label saying what model tranny it was. i also had to remove the axles to see.
and yes it was LSD . spinning the tires trick doesn't work when looking for LSD.
Old Jul 19, 2006 | 08:44 AM
dragaholic's Avatar
well it is a y21 I got and I think they come with lsd as an option. So I guess I'll wait and see when I'm changing CVs.
The thing is the car launches very aggresively. not like ah pegleg.
Old Jul 19, 2006 | 11:00 AM
JDM B16A's Avatar
Default Re: (dragaholic)
So, next time before trying to give someone a piece of your mind. MAKE SURE you have enough to SPARE!!!
Old Jul 20, 2006 | 04:38 PM
dragaholic's Avatar
ok here's a pic(big pic). I'm the hatch.
Old Jul 20, 2006 | 06:45 PM
Bense's Avatar
Default Re: (JDM B16A)
open diffs light up both wheels most of the time.
my quaife spins both wheels when in neutral. Put the car in gear, like 5th gear. lift it off the ground, and turn a wheel. If it spins in the opposite direction, you def have a open diff. if they both spin in the same direction, get a friend to hold one with slight pressure. if he can easility hold it while you spin, open diff.
or just put one wheel in grass, one wheel on street, and dump it! if you sit there spinning, open diff!
Old Jul 20, 2006 | 06:48 PM
ekb16's Avatar
spinning the tires should tell if its lsd or not..i have a ITR lsd tranny and my tires spin the same direction
Old Jul 20, 2006 | 07:11 PM
Bense's Avatar
Default Re: (ekb16)
1 tire in grass, 1 tire on cement, DUMP IT
Old Jul 20, 2006 | 08:07 PM
Built Beast's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by poison &raquo;</TD></TR><TR><TD CLASS="quote">LSD type (courtesy of Ninety2SiR)
If you can NOT look thru it, then you do not have LSD.
2SICK2EVENCARE
Jan 31, 2010 02:06 PM
b16a3delsol
May 14, 2007 06:36 AM
deesracer
Jul 14, 2004 04:02 AM
crzyfool24
24
Apr 2, 2004 10:33 PM
red_hatch92
14
Jul 16, 2003 06:45 PM
