LSD tranny
LSD tranny
Hi guys,
Is it possible to tell if a tranny is lsd or not without removing the axles?
I heard that if you spin one tyre and the other spins in the same direction then you have an lsd tranny. If it spins in the opposite direction its an open diff.
Can someone confirm this.
Re: LSD tranny (JDM B16A)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM B16A »</TD></TR><TR><TD CLASS="quote">No way of telling if a tranny is equipped with LSD. You have to the axles off. </TD></TR></TABLE>
It says it right on the tranny, by the serial # or vin # or whatever, it says "LSD" - if not then it's not LSD
cute little bastard
Re: LSD tranny (dragaholic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dragaholic »</TD></TR><TR><TD CLASS="quote">Hi guys,
Not always true. My stock Y21 w/ LSD on my car spins in the same direction. But I've heard that ITR trannys don't do this and they have LSD
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Syndacate »</TD></TR><TR><TD CLASS="quote">
It says it right on the tranny, by the serial # or vin # or whatever, it says "LSD" - if not then it's not LSD</TD></TR></TABLE>
Not true either. My Y21 doesn't say anything but I looked through the differential, no rod
Re: LSD tranny (Syndacate)
not true. when i did my swap my tranny(JDM B16A) had no LSD stamp nor the label saying what model tranny it was. i also had to remove the axles to see.
and yes it was LSD . spinning the tires trick doesn't work when looking for LSD.
well it is a y21 I got and I think they come with lsd as an option. So I guess I'll wait and see when I'm changing CVs.
The thing is the car launches very aggresively. not like ah pegleg.
Re: (dragaholic)
So, next time before trying to give someone a piece of your mind. MAKE SURE you have enough to SPARE!!!
Go Tigers!
Re: (JDM B16A)
open diffs light up both wheels most of the time.
my quaife spins both wheels when in neutral. Put the car in gear, like 5th gear. lift it off the ground, and turn a wheel. If it spins in the opposite direction, you def have a open diff. if they both spin in the same direction, get a friend to hold one with slight pressure. if he can easility hold it while you spin, open diff.
or just put one wheel in grass, one wheel on street, and dump it! if you sit there spinning, open diff!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by poison »</TD></TR><TR><TD CLASS="quote">LSD type (courtesy of Ninety2SiR)
If you can NOT look thru it, then you do not have LSD.
deesracer
07-14-2004 04:02 AM
red_hatch92
14
07-16-2003 06:45 PM
