How to tell the difference between jdm lsd tranny and stock..
Does anyone know how to tell Just by looking at a hydraulic tranny and tell if it's lsd or not. I just bought this complete jdm b18c and i was told it was lsd equipped. But it does'nt say LSD on the casing like usdm type-r trannies. I also heard something about looking inside where the axles go and look for some sort of pin. Or is there any kind of casting #s. If anyoneknows please let me know.....thanx!!
Re: How to tell the difference between jdm lsd tranny and stock.. (deesracer)
I was told if you look where the axles go into the tranny and you can see straight through, then you have a LSD tranny. If you see a pin, then you do not.
at the jetties fishin'
Re: How to tell the difference between jdm lsd tranny and stock.. (93Civac)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93Civac »</TD></TR><TR><TD CLASS="quote">I was told if you look where the axles go into the tranny and you can see straight through, then you have a LSD tranny. If you see a pin, then you do not.</TD></TR></TABLE>
you are correct sir! Also, you can slide the cv shafts in there real quick and give one a turn, if the other turns the same way then you know for certain it's a posi.
Re: How to tell the difference between jdm lsd tranny and stock.. (stackz)
1 Post
That is the only way that I am aware of as well..
Re: How to tell the difference between jdm lsd tranny and stock.. (93CivicSI)
yea, i asked the same question last week.... pull out the axle shafts and the intermediate shaft and if u can see through the hole u have lsd, if there is a shift going through the middle of the hole then there is no lsd
i thought i got scammed to buddy
Re: How to tell the difference between jdm lsd tranny and stock.. (tallblondkid)
and now i actually read the whole thread and i see you already figured it out
red_hatch92
14
07-16-2003 06:45 PM
