Name This Sensor
Old Jul 18, 2006 | 10:11 AM
ExCon's Avatar
Default Name This Sensor
its off a y8. the sensor has one green wire and appears to have another one that was cut at the base of the sensor, that one also appears to be green. the wire that isnt cut seems to be connected to the vtec solenoid area, after it joins the rest of the vtec wires it just runs through the fire wall.
Old Jul 18, 2006 | 10:57 AM
NJcoupe's Avatar
Knock Sensor.
Old Jul 18, 2006 | 02:15 PM
ExCon's Avatar
Default Re: (dxcoupe.)
are you sure! i thought that the knock sensor was threaded into the the block under the intake manifold!? this sensor doesnt appear to have any threads!
Old Jul 18, 2006 | 03:05 PM
ExCon's Avatar
Default Re: (NOjdmHERE)
ttt
Old Jul 18, 2006 | 03:13 PM
Discosteak's Avatar
i doesnt have any treads because its broken. they break all the time. the better part of the sensor is probably still in the block
Old Jul 18, 2006 | 03:22 PM
ExCon's Avatar
Default Re: (badeg4)
can you guys confirm that it is a knock sensor for a y8
Old Jul 18, 2006 | 03:32 PM
-Gambit-'s Avatar
i vote broken knock with the rest of it still in the block
Old Jul 18, 2006 | 08:47 PM
NJcoupe's Avatar
Default Re: (-Gambit-)
Its a blue sensor, its a knock sensor.
Old Jul 19, 2006 | 01:56 PM
Discosteak's Avatar
yes it was a knock sesor for a y8 now it is garbage
92'si
Feb 8, 2010 06:27 PM
97blacklude
Jan 31, 2009 09:56 AM
quicky_hatch12
Oct 7, 2005 11:59 AM
DevinW
Oct 28, 2002 05:35 PM
