Brake caliper questionW
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by E.Honda »</TD></TR><TR><TD CLASS="quote">Will the front calipers from a 94 integra fit a 93 civic ex?
Thank you.</TD></TR></TABLE>
Yes, they will bolt right on.
If your EX is a 4-door, you already have the exact same calipers as the Integra (17CL14VN). If your EX is a 2-door, the Integra calipers will have slightly larger pistons than your stock calipers so it will be a minor upgrade.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy »</TD></TR><TR><TD CLASS="quote">No, you missed it by one year</TD></TR></TABLE>
Nope, all EXes have 10.3" front brakes so he will be fine.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Targa250R »</TD></TR><TR><TD CLASS="quote">
Nope, all EXes have 10.3" front brakes so he will be fine.</TD></TR></TABLE>
I am more concerned with the mounting holes matching.
Yes, I looked up the part numbers before I posted. The 92-93 had different numbers from the 94-95. The 94-95 had the same part numbers as the Integra.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by E.Honda »</TD></TR><TR><TD CLASS="quote">I am more concerned with the mounting holes matching.</TD></TR></TABLE>
They will bolt right up, because the '92-95 EX and '94-01 Integra use the same knuckle.
Well, if he has an EX-S or EX-ABS then he'll have the same knuckle. Otherwise the 1993 Civic EX does not have the same knuckle as the Integra.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy »</TD></TR><TR><TD CLASS="quote">Well, if he has an EX-S or EX-ABS then he'll have the same knuckle. Otherwise the 1993 Civic EX does not have the same knuckle as the Integra.</TD></TR></TABLE>
Yes it does. I owned a '93 EX coupe (non S package). It had 10.3" front rotors and 16CL14VN calipers. Rears were drum.
No Civic EX has ever been made with rotors smaller than 10.3" since the trim level's introduction in 1990.
No Civic EX has ever been made with rotors smaller than 10.3" since the trim level's introduction in 1990.</TD></TR></TABLE>
Ok, I might be confused with the Si. For sure the 92-93 Si's had 9.5" rotors.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy »</TD></TR><TR><TD CLASS="quote">Ok, I might be confused with the Si. For sure the 92-93 Si's had 9.5" rotors.</TD></TR></TABLE>
That's correct. All '92-95 Si hatchbacks had 9.5" fronts except for the '94 Si-ABS, which had Integra brakes.
EX != Si
EX != Si
dr_latino999
Oct 28, 2006 02:01 PM
on me.
