Integra vs Civic Ex calipers
I know the rotors are the same size but I've been surfing through all the FAQ and stuff on this site and no one seems to know ( definitively ) if the integra calipers are the same or bigger than the Civic Ex ones. Anyone want to chime in for a definitive answer?
Re: (sohcvtec1995)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sohcvtec1995 »</TD></TR><TR><TD CLASS="quote">they are different. some say the EX one is better, some say the teg one is better.</TD></TR></TABLE>
? I've heard some people say the Integra calipers are bigger but I've never heard anyone say the Ex ones were better, only the same as the Integras.
Re: Integra vs Civic Ex calipers (BlueIntegraBoy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy »</TD></TR><TR><TD CLASS="quote">Piston on Integra caliper is larger</TD></TR></TABLE>
EX 4dr calipers have a bigger piston then the EX coupe.
went through some hoops this past weekend changing brakes...
92 Vx with EX hubs...when to change the brakes (pads /rotors)
got new calipers from advanced... EX 4drs.
compared them to the 2dr coupes & they have bigger pistons.
so current setup is EX/teg rotors (brembo blanks) EX caliper brackets with Brembo pads & EX 4dr calipers.
so far it seems really good.
Re: Integra vs Civic Ex calipers (philosofy1)
larger then EX 4dr too?
cause the EX 4dr has bigger pistons then the EX coupe
had then both in my had & the 4dr ones were noticably bigger (we measured too but forget the difference)
Re: Integra vs Civic Ex calipers (crxsrule)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxsrule »</TD></TR><TR><TD CLASS="quote">Neither one is going to make that much of a difference</TD></TR></TABLE>
it will if your changing all 4 corners and upsize the m/c., and if your going from a dx set up like mine.
Re: Integra vs Civic Ex calipers (APCforthewin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by APCforthewin »</TD></TR><TR><TD CLASS="quote">I was told integras use the same pistons in their calipers as 4dr ex's. IM not sure yet..</TD></TR></TABLE>
i heard something like that too.
Re: Integra vs Civic Ex calipers (jmayhew)
on the flip side, which is my problem, can you leave a dx (del Sol S) stock forks and control arms and simply swap out the rotors and calipers with a teg (nonITR). this is the last thing I gotta do. Already swapped teg rear discs on, and that took the entire sub assy. The brake booster and MS went on like a charm after I bent the lines to fit. Really hope this is feasible.
Re: Integra vs Civic Ex calipers (outtacontrolsol)
The 94-01 Integra calipers all use the same size caliper, and the 96-00 civics use the integra caliper, and one that honda has, for both 4 door and 2 door models, It seems that the plant in West Liberty used old stock on some newer civics, namely the late year 99's and 2000 model civics, LX trim and above, that used the bigger (and older) integra calipers, I fould this out after I had to change wheel bearings, and non ABS bearings for my year civic (2000) didnt fit, I was wierded out by it, but I got some additional information from a retired military man that worked at the Liberty plant for a while, and knew some of the ups and downs with parts, it seems they used integra knuckles on my 00 Civic EX coupe, non ABS, as the VIN states, but only ABS bearings from any 94-01 Integra will fit them. the only way to know is by the part casting, since it affected many later model 99-00 civics, it is uncertain which ones ended up where.
Jonathan_ED3
15
04-01-2004 09:27 AM
E-Rok
01-10-2004 03:28 PM
