CEL 41 (Heated O2) Replaced and still throwin code
Old Jul 17, 2006 | 05:15 PM
commotion's Avatar
Default CEL 41 (Heated O2) Replaced and still throwin code
i replaced this and also my brothers car is throwing the same code i have a 95 ex and he has a 93 ex with new 160$ o2's wasted money if that wasnt the problem please help anyone else have the problem???
Old Jul 17, 2006 | 05:19 PM
Runnerdown's Avatar
Default Re: CEL 41 (Heated O2) Replaced and still throwin code (commotion)
Look carefully at the connector, and see if there is green corrosion on the terminals inside.
Syndacate's Avatar
Hrm, says "Primary Oxygen Sensor Heater"
I don't know what that is...
so bump*
Old Jul 17, 2006 | 05:21 PM
commotion's Avatar
Default Re: (Syndacate)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Syndacate &raquo;</TD></TR><TR><TD CLASS="quote">Hrm, says "Primary Oxygen Sensor Heater"
so bump*</TD></TR></TABLE>
it is a heated O2 and since my car has only 1 O2 it is my primary so yah not sure my self
Old Jul 17, 2006 | 06:06 PM
eg9's Avatar
eg9
Default Re: (commotion)
Had the same problem all I did was try another ecu and that solved the problem. Mine was in a 93 dx 4dr civic w/ y8 swap running a p28. I just switched with another p28 and that was it.
Old Jul 17, 2006 | 06:10 PM
eg9's Avatar
eg9
certain year ecu's/models had the code 41. I think it was the older models had the o2 heater deal and the newer ecu's didn't. I put a 95 si p28 in and it went away. The ecu that kept throwing code 41 was a 93 si ecu.
Old Jul 17, 2006 | 11:32 PM
commotion's Avatar
Default Re: (eg6vtec)
wow anyway to order or do i have to junk yard it?
Old Jul 18, 2006 | 04:38 AM
eg9's Avatar
eg9
best thing to do is get one you know is a good ecu. If junkyard is only way then might be the best way. You might be able to get an ecu off here fairly cheap shipped to you from someone. Junkyards could be fairly expensive and always no way to tell if it is any good from them. $75-$150 is average price for a good used p28
Vomit
Nov 20, 2013 08:24 PM
lance_ecl
Mar 6, 2008 08:27 PM
TylerH
Apr 16, 2004 09:58 AM
VTC_CiViC
Apr 18, 2003 10:12 AM
