fuel pump does not engage.... help
Old Jul 17, 2006 | 03:10 PM
CO_CReX's Avatar
Default fuel pump does not engage.... help
Hey my buddy has got a b18c motor with a t28 turbo in a 92 civic dx. after we put the turbo on, the fuel pump no longer engages. we cant hear it click, and the car will not start...... any ideas on how to fix this??
thanks
Old Jul 17, 2006 | 03:18 PM
CO_CReX's Avatar
Default Re: fuel pump does not engage.... help (CO_CReX)
ttt
Old Jul 17, 2006 | 03:28 PM
x2gold's Avatar
Sure, check your grounds...esp thermostat and valve cover one. Add one as well, somewhere along the manifold(s). Then check your main relay. They seem to be known to go in the hot summer heat. Just happened to me after my ls turbo swap. Good luck, hope this helps.
Old Jul 17, 2006 | 03:48 PM
CO_CReX's Avatar
Default Re: fuel pump does not engage.... help (x2gold)
alright ill check it and see what happens..
Old Jul 17, 2006 | 04:32 PM
CO_CReX's Avatar
we can hear the realy click, but the pump doesnt engage.. also we tried to see if the fuel rail was getting any fuel and it had like 2 drops.. any other suggestions?? it ran yesterday just fine... we just slapped a t28 and 450 injectors.. we had the ecu chipped, but that wasnt the case, we tried another one non chipped, i still cant hear it engage..
thanks
Old Jul 17, 2006 | 04:44 PM
CO_CReX's Avatar
Alright this is how i wired up the resistor box exactly..
Modified by CO_CReX at 3:06 PM 7/18/2006
Old Jul 18, 2006 | 05:13 PM
x2gold's Avatar
what box are you using....mitsu or honda (crx - prelude ) ? Might have a bad resistor box.
Old Jul 18, 2006 | 06:23 PM
SuperSteve737's Avatar
Main relay???
ek201
Dec 20, 2010 10:21 PM
teknohatchie91
Apr 15, 2009 11:40 AM
Siegfried
Aug 21, 2006 11:17 AM
rluder21
Mar 25, 2006 09:26 AM
Archidictus
Aug 12, 2002 03:58 PM
