Burnt valve?
Old Jul 17, 2006 | 12:59 AM
JFG Kevin's Avatar
Default Burnt valve?
So yah...i think i burnt my valve cause as i was gunning the car on the freeway cause i was messing around with a mustang and in 5th gear around 7 grand i felt a lost of power. Didn't feel good to me so i backed off the gas and look back i was spitting alot of black smoke smelling like i just brew out some birthday candles. im thinking it's a burnt valve, if it is probably going to rebuild with ferreas. It's also idling pretty shitty and a huge lost of power on the low end cause it feels like one of the cyclinder is not getting firing at all.
Old Jul 17, 2006 | 04:35 AM
Duane_in_Japan's Avatar
Default Re: Burnt valve? (aznstyler119)
You need to do a dry then a wet compression test, if bad then do a leak down test which a shop may have to do for you.
Old Jul 17, 2006 | 10:27 AM
JFG Kevin's Avatar
Default Re: Burnt valve? (Duane_in_Japan)
What are the differance between a wet and dry compression test?
Old Jul 17, 2006 | 11:46 AM
RJonathan's Avatar
I believe a dry compression test is just doing a compression test with the car at normal temperature. a Wet compression test is when you add like a teaspoon of oil in each cylinder to see if compression bumped up at all.
Old Jul 17, 2006 | 12:32 PM
JFG Kevin's Avatar
Default Re: Burnt valve? (RJonathan)
o ic.....well...i kinda figure out my problem b4 i did the compression then...seem to me that i have a supa blown headgasket from the amount of white smoke i am put out...
Old Jul 17, 2006 | 01:00 PM
gsr dood's Avatar
7k in 5th????!?!?!?! **** man slow the expletive down
Old Jul 17, 2006 | 01:17 PM
JFG Kevin's Avatar
Default Re: Burnt valve? (gsr dood)
haha...Bay area freeway...580 is fun...yah..not to mention i had to take a ****...badly...tryin to get home..
Old Jul 17, 2006 | 01:30 PM
toguemaster's Avatar
I can pretty much guarantee thats what it is. I had the same thing happen with my previous car, a 91 civic si. I was at about 75 mph when I felt a sudden loss of power and saw a huge cloud of smoke out the back and I freaked out. Come to find out I had a burnt valve and ended up selling it instead of rebuilding it. It was one of the saddest days of my life. (A moment of silence here would greatly be appreciated).
Old Jul 17, 2006 | 02:15 PM
B18c5__Owns's Avatar
From: I Bet You Really Want To Know Where In, NJ, USA
Default Re: Burnt valve? (toguemaster)
I had the same thing happen to be. But it wasnt a headgasket. It turned out to be I broke the piston and scratched the wall a little
Old Jul 17, 2006 | 02:16 PM
Same thing happened to be, But it was a cracked piston. Luckly i can get it honed.
Old Jul 17, 2006 | 03:33 PM
BrooX's Avatar
Get a tech to take a look at it asap. If you are sure you have bad valves it could cause a cylinder missfire which in turn will cost you more money for parts and repair down the line. I've seen it happen is all i'm saying.
Old Jul 17, 2006 | 06:08 PM
jared99's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by toguemaster &raquo;</TD></TR><TR><TD CLASS="quote">I can pretty much guarantee thats what it is. I had the same thing happen with my previous car, a 91 civic si. I was at about 75 mph when I felt a sudden loss of power and saw a huge cloud of smoke out the back and I freaked out. Come to find out I had a burnt valve and ended up selling it instead of rebuilding it. It was one of the saddest days of my life. (A moment of silence here would greatly be appreciated). </TD></TR></TABLE>
Are you sure you had to rebuild? I'm assuming something else was screwed up as well. I burned a valve, and did a head swap with another LS head and was fine.
Old Jul 17, 2006 | 09:00 PM
Fat Chick Magnet's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aznstyler119 &raquo;</TD></TR><TR><TD CLASS="quote">haha...Bay area freeway...580 is fun...yah..not to mention i had to take a ****...badly...tryin to get home..</TD></TR></TABLE>
hahahahahahahahha so did you take a **** in your pants once you saw all that black smoke or got home on time?
Old Jul 18, 2006 | 01:41 AM
JFG Kevin's Avatar
Default Re: Burnt valve? (dc2rtek)
i got home fast enough to take a ****...i could careless what had happen to my car at the time cause i knew something was FUCKED ALREADY...as long as i can get the car home that's all i care for. The reason why i can assum that it' smy headgasket is that it's not like i was near red line cause my redline is at 9. plus the car is spitting out HELLA white smoke...so that's usually a sign of a blown headgasket..
Old Jul 18, 2006 | 08:35 AM
trick_db's Avatar
it can be, do a compression test and see what you can come up. in some occasion. white smoke mean piston ring? not really sure but yea. when headgasket is gone, usualy it get hot and over heat
Old Jul 19, 2006 | 07:49 PM
JFG Kevin's Avatar
Default Re: Burnt valve? (trick_db)
https://honda-tech.com/zerothread?id=1695297
that is what happen...
civic-one
Apr 6, 2011 08:02 AM
SilkyJohnson
13
Feb 15, 2011 05:54 PM
dreamreaperx
Dec 20, 2006 02:01 PM
EF8_SiR
Jul 20, 2003 10:24 PM
