* HOW DO YOU INSTALL JDM THIN SIDE MOLDINGS ON A EK *
Old Jul 16, 2006 | 11:52 PM
IT'S ME DAVID's Avatar
NooB
Default * HOW DO YOU INSTALL JDM THIN SIDE MOLDINGS ON A EK *
exactly how the title states.is there a link or picture thread that details this.reason why i ask is because people say you can damage the paint on the car if not done correctly.
Old Jul 16, 2006 | 11:55 PM
fms1day's Avatar
Default Re: * HOW DO YOU INSTALL JDM THIN SIDE MOLDINGS ON A EK * (IT'S ME DAVID)
clips? or double stick tap?
Old Jul 17, 2006 | 12:03 AM
Mysterious's Avatar
Default Re: * HOW DO YOU INSTALL JDM THIN SIDE MOLDINGS ON A EK * (fms1day)
for clips, you have to open up your panels and pop it out by squeezing the clips with your fingers or something. some might have double sided tape on them so watch out
Old Jul 17, 2006 | 12:31 AM
NooB
Default Re: * HOW DO YOU INSTALL JDM THIN SIDE MOLDINGS ON A EK * (Mysterious)
na ther the clips type.
Old Jul 17, 2006 | 12:33 AM
fms1day's Avatar
If you're looking to remove the old ones.. then you remove the door panel and push the clips out... if you're looking to install, one would assume to just push the clips in?
Unless your EK doesn't have side molding holes.... if that's the case, you can always put some tape over the spots you're going to drill holes into to somewhat protect the paint.
Old Jul 17, 2006 | 12:38 AM
NooB
I WA JUST HOPING THERE waSa eazy way of doing this without having to remove the panels.
Old Jul 17, 2006 | 12:47 AM
fms1day's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IT’S ME DAVID &raquo;</TD></TR><TR><TD CLASS="quote">I WA JUST HOPING THERE waSa eazy way of doing this without having to remove the panels.</TD></TR></TABLE>
Oh, not without prying I bet. Nothing worse than messing up the paint than to put a little more time and hassle into taking the door panels off
Old Jul 17, 2006 | 09:57 AM
NooB
yea ok thanks for the info guys.
Old Aug 16, 2009 | 06:03 PM
import-tooner's Avatar
Just got done doing the back ones on my EK. The two rear clips are easy enough to push out if you have your interior panels removed. The third one that is toward the front of the car on the rear trim piece is harder... or so it seams. Just push the molding forward after you release the other two clips. The molding will pop off and you can remove the clip from the exterior of the body.
Haven't done the clips on the door yet but they should be pretty easy.
Old Aug 16, 2009 | 06:24 PM
92ehatch's Avatar
if you dont care to break the clips on your factory moldings, then just pull em off, i have done that before and it didnt hurt anything.
Old Aug 16, 2009 | 09:56 PM
Linked's Avatar
x2
quick and you dont gotta remove the door panels and that annoying little plastic covering that i believe is an important part (damn enviroment)
Old Aug 18, 2009 | 06:40 AM
92ehatch's Avatar
Originally Posted by Linked
x2
oh yeah, almost forgot, dont just yank them out of the fenders. you can bend your fenders. (thin metal)
the doors and the rear quarter are ok to just pull them out
dopamean
Nov 23, 2008 11:48 AM
turnsignalandy
11
Feb 23, 2008 06:15 PM
length
Nov 11, 2003 07:02 AM
JDM CTR EK
14
May 18, 2003 02:14 PM
1 speedstar
Mar 31, 2003 04:34 PM
