* HOW DO YOU INSTALL JDM THIN SIDE MOLDINGS ON A EK *
Re: * HOW DO YOU INSTALL JDM THIN SIDE MOLDINGS ON A EK * (fms1day)
for clips, you have to open up your panels and pop it out by squeezing the clips with your fingers or something. some might have double sided tape on them so watch out
1 Post
Re: * HOW DO YOU INSTALL JDM THIN SIDE MOLDINGS ON A EK * (IT'S ME DAVID)
If you're looking to remove the old ones.. then you remove the door panel and push the clips out... if you're looking to install, one would assume to just push the clips in?
Unless your EK doesn't have side molding holes.... if that's the case, you can always put some tape over the spots you're going to drill holes into to somewhat protect the paint.
1 Post
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IT’S ME DAVID »</TD></TR><TR><TD CLASS="quote">I WA JUST HOPING THERE waSa eazy way of doing this without having to remove the panels.</TD></TR></TABLE>
Oh, not without prying I bet. Nothing worse than messing up the paint than to put a little more time and hassle into taking the door panels off
Just got done doing the back ones on my EK. The two rear clips are easy enough to push out if you have your interior panels removed. The third one that is toward the front of the car on the rear trim piece is harder... or so it seams. Just push the molding forward after you release the other two clips. The molding will pop off and you can remove the clip from the exterior of the body.
Haven't done the clips on the door yet but they should be pretty easy.
if you dont care to break the clips on your factory moldings, then just pull em off, i have done that before and it didnt hurt anything.
quick and you dont gotta remove the door panels and that annoying little plastic covering that i believe is an important part (damn enviroment)
the doors and the rear quarter are ok to just pull them out
turnsignalandy
11
02-23-2008 06:15 PM
JDM CTR EK
14
05-18-2003 02:14 PM
1 speedstar
03-31-2003 04:34 PM
