88 CRX Si oil pressure drop - any ideas???
Old Jul 15, 2006 | 05:56 PM
Swiss Gary's Avatar
Default 88 CRX Si oil pressure drop - any ideas???
I was at the NASA/PDA event this last Friday at Pocono S and the day was pretty hot 85 F & Hmind..). My 88 CRX Si was running very well and during the middle of the third track session, the oil pressure started to drop. I drove the car back as there was some pressure registering on the gague. It normally reads in the 50 +/- 5 area but now only just registers on the scale. I checked and there are no leaks and the dip stick look A-OK. The reader 'looks' OK but who knows what can go wrong with those fellas...
Anyway, I let the car cool right down and fired her up only to see the pressure in the 25 area but no higher. The oil is Mobil 1 synthetic with only 2 hours max on it.
There are no apparent metallic pieces on the dip stick in the oil, by the way though I will drain the oil tomorrow and see if there are any apparent metallic shards present.
Anyway, anyone out there got any ideas as to what my problem is? Surely of the oil pump is shot there would be no pressure registering at all.
Many thanks in advance
Gary
88 CRX Si - 1875 LB
Old Jul 15, 2006 | 06:41 PM
jackinthetrunk's Avatar
Default Re: 88 CRX Si oil pressure drop - any ideas??? (Swiss Gary)
maybe spun bearing.
Old Jul 15, 2006 | 08:24 PM
Crx Jimmy's Avatar
25psi is fine at idle(when warm) my pressure goes up to 80-100psi at 8000 rpm, but at idle the pressure is usually low
Old Jul 15, 2006 | 08:58 PM
fourthgenhatchB17's Avatar
Default Re: 88 CRX Si oil pressure drop - any ideas??? (Crx Jimmy)
Mechanical or electric gauge? What rpms are u seeing those pressure #'s at?
Old Jul 16, 2006 | 07:53 AM
JOE BD-0's Avatar
Swiss Gary, you might want to check and see if you may have pushed the bottom of the oil pan up into the bottom of the oil pickup....this happens sometimes when you drive over the "tiger teeth" (red and white bumps) on the inside corners of the racetrack....I have even contemplated fabricating a standoff bracket inside the oil pan to prevent this from happening.....
Old Jul 16, 2006 | 10:57 AM
Swiss Gary's Avatar
Default Re: 88 CRX Si oil pressure drop - any ideas??? (fourthgenhatchB17)
Err - Oil line from block goes into 'sender' unit that has a wire out of the top that feeds the oil pressure guage. Doesn't look like much could go wrong but who knows..
Old Jul 16, 2006 | 11:00 AM
Swiss Gary's Avatar
Oh yeah; the pressures. AT idle the needle is basically off the guage but at 3000 - 5000 the pressure doesn't go past 25 PSI. It used to before that last session where it simply fell off. I read that I should have around 50 PSI at 5000 RPM so do not want to chance things yet.
Swiss Gary's Avatar
Default Re: 88 CRX Si oil pressure drop - any ideas??? (jackinthetrunk)
Meaning - remove & replace or worse?
Old Jul 16, 2006 | 11:01 AM
Swiss Gary's Avatar
Default Re: 88 CRX Si oil pressure drop - any ideas??? (JOE BD-0)
Thanks - I'll take a look as I ran a few burns, as one does, to try & keep the corvette's off my tail..
Old Jul 16, 2006 | 11:04 AM
Loserkidwac's Avatar
I've heard of some people haveing autometer elec sending units go bad, maybe slap a mechanical gauge on to see if it reads the same...hopefully you guage went bad
aznd87
Nov 6, 2006 01:32 PM
toooslow
Oct 19, 2003 04:05 PM
LSVTECoupe
Aug 30, 2003 08:52 AM
Snafu-Si
Mar 24, 2003 10:47 PM
