Oil pressure help!
Old Apr 21, 2002 | 12:03 AM
ion_four's Avatar
Default Oil pressure help!
I want to avoid taking the oil sender out twice (so I can find the size, and then put it in and drive to the hardware store and take it out again to put in a hose end and run it to a T...) so, does anyone know what the size and thread is on a 93 Civic D16z6? I'm going to do it this way...pretty cool. http://www.theoldone.com/articles/oilpressure/
Thanks!
Old Apr 21, 2002 | 12:19 AM
Rocket's Avatar
Default Re: Oil pressure help! (ion_four)
1/8 NPT works.
Old Apr 21, 2002 | 12:24 AM
ion_four's Avatar
Default Re: Oil pressure help! (Rocket)
1/8 NPT works.
That's what fits right into the block? Thanks!
Old Apr 21, 2002 | 09:05 AM
clockworks's Avatar
If you want to do it right, it's 1/8"BSPT.
Old Apr 21, 2002 | 11:05 AM
ion_four's Avatar
Default Re: Oil pressure help! (clockworks)
So, which is it? I'm not exactly sure what NPT or BSPT means...is BSPT the fitting used for steel braided lines? I'm just going to use high pressure hose with some slack and mount it well...so, can I use either fitting?
Old Apr 21, 2002 | 12:00 PM
ion_four's Avatar
Also...will I have to drain off some of the oil before I take off the filter? or if the car's cold should it be low enough to not lose much?
Old Apr 21, 2002 | 12:26 PM
Giuseppe's Avatar
autometer part #2269... 1/8BSPT to 1/8NPT
and yes u can take your oil filter out without draining the oil..
hth
Old Apr 22, 2002 | 06:53 PM
ricin97civic's Avatar
Ok, i'm doing the same install on my 97 civic. I have went to the big and small hardware stores and the same with auto parts stores. Why can't I find a 1/8" tee fitting!?!??!?!?!? The guy at Advanced Auto Parts said his buddy had to order the tee fitting when he redid his civic engine. Is something of this size really that hard to find??
Old Apr 23, 2002 | 06:34 AM
Giuseppe's Avatar
Default Re: Oil pressure help! (ricin97civic)
homedepot!
[Modified by Giuseppe, 3:35 PM 4/23/2002]
javantie
Apr 22, 2015 02:10 PM
NIGHTRIDER27
Apr 9, 2008 06:51 PM
BMaDOHC
Apr 24, 2006 02:01 PM
harryg
Sep 18, 2003 05:22 PM
stockgreencivic
Apr 11, 2003 01:52 AM
