Question on Viper 5000
doing an install on a viper 5000...
and i was wondering if the "factory disarm out (-)" is basically a "ground when disarmed"??
if it is, then i don't have to go and redo that wire
cause i just did all the wiring.. now just have to install the sirens, and hook up the brain.. and install the fuse to make the wire live....
if the "factory disarm out (-)" is not a "ground when disarmed" that means i have to take out the ground when armed, and hook it up to a relay... to invert it...
which is what i do not want to do...
their should be a description of each wire in the install manual, but yes it should give a short neg. pulse when you disarm. it might also give a pulse when other channels are used.
the manual doesn't say much, other than its also activated when channel 2 is activated...
All i know is that i can program the disarm wire to activate either with channel 2 or just when u disarm the alarm...
also that it is a neg/ground wire when activated....
it doesn't say if it pulses or not...
if it just comes down to it.. i guess i'm going to have to test the wire... when i finally make the alarm live...
sohcturbo92vx
Jan 13, 2012 04:42 PM
NegativeXero
Sep 10, 2007 05:57 PM
