Question on Viper 5000
Old Jul 13, 2006 | 09:56 PM
bpr0422's Avatar
Default Question on Viper 5000
doing an install on a viper 5000...
and i was wondering if the "factory disarm out (-)" is basically a "ground when disarmed"??
if it is, then i don't have to go and redo that wire
cause i just did all the wiring.. now just have to install the sirens, and hook up the brain.. and install the fuse to make the wire live....
if the "factory disarm out (-)" is not a "ground when disarmed" that means i have to take out the ground when armed, and hook it up to a relay... to invert it...
which is what i do not want to do...
Old Jul 13, 2006 | 10:57 PM
wrx-killer-Sti-eater's Avatar
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
Default Re: Question on Viper 5000 (bpr0422)
What kind of car are you working on ?
Old Jul 14, 2006 | 04:32 PM
JSPECSIR's Avatar
Default Re: Question on Viper 5000 (wrx-killer-Sti eater)
their should be a description of each wire in the install manual, but yes it should give a short neg. pulse when you disarm. it might also give a pulse when other channels are used.
Old Jul 14, 2006 | 07:32 PM
bpr0422's Avatar
Default Re: Question on Viper 5000 (JSPECSIR)
the manual doesn't say much, other than its also activated when channel 2 is activated...
All i know is that i can program the disarm wire to activate either with channel 2 or just when u disarm the alarm...
also that it is a neg/ground wire when activated....
it doesn't say if it pulses or not...
if it just comes down to it.. i guess i'm going to have to test the wire... when i finally make the alarm live...
Old Jul 15, 2006 | 03:48 AM
JSPECSIR's Avatar
yeah it should just be a pulse, it may have more options with a bitwriter. you'll probably need version 2.3 if you dont already have it.
sohcturbo92vx
Jan 13, 2012 04:42 PM
NegativeXero
Sep 10, 2007 05:57 PM
letsstophere
Audio / Security / Video
Jan 5, 2006 10:20 AM
SleekBlkPrelude
Mar 26, 2003 12:09 PM
accord-euro-r
Sep 22, 2002 09:16 AM
