K20A2 swap into EP3
Old Jul 13, 2006 | 09:23 PM
Ep3_boI's Avatar
Default K20A2 swap into EP3
i was wonder how do i get the shifter to stay on the dash, people have told me that u have to dissassemble tha shift assembly and cut out or ground off the travel stop.I have no clue what that means though.does n e body know how to do it ?
Old Jul 14, 2006 | 09:21 PM
BarracksSi's Avatar
All they're saying is that there's a little piece within the shifter mechanism that you'd likely need to grind down to allow the shifter to go to the new 6-speed reverse gear. Some haven't needed to do it, but it should be part of the swap plans.
The shifter stays in the dash, right where God and Nature intended.
You could also get a Buddy Club short shifter kit, which is designed for the 6-speed in the first place and does a good job of making even shorter throws.
Old Jul 14, 2006 | 10:10 PM
EP3tune2RULE's Avatar
Default Re: (BarracksSi)
+1 to BarracksSi for having the best knowledge on EP3s, very informative each and every posts you've made here and @ ephatch ...
Old Jul 15, 2006 | 10:29 AM
Isy25's Avatar
i did a a2 swap into my buddies ep for him and he had neuspeed short shifter adapter and we never had to shave the shifter in the dash at all and he has never had any problems with it...
Old Jul 16, 2006 | 06:09 PM
Ep3_boI's Avatar
Oh wow i didnt know that thanx a lot for the information this should make the swap a lot easier for me.Oh another question i had was would i have to do the same thing if i were to swap the K20A type-R into my Ep3?And how do i put a LSD in also.because i use to have a RSX-s untill i flipped it .so i really never had to worrie about swaps
Old Jul 16, 2006 | 09:48 PM
BarracksSi's Avatar
Default Re: (EP3tune2RULE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EP3tune2RULE &raquo;</TD></TR><TR><TD CLASS="quote">+1 to BarracksSi for having the best knowledge on EP3s, very informative each and every posts you've made here and @ ephatch ...</TD></TR></TABLE>
That's because I keep my mouth shut when I don't know what the hell to say..
Old Jul 16, 2006 | 09:50 PM
BarracksSi's Avatar
Default Re: (Ep3_boI)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ep3_boI &raquo;</TD></TR><TR><TD CLASS="quote">... would i have to do the same thing if i were to swap the K20A type-R into my Ep3?And how do i put a LSD in also.</TD></TR></TABLE>
Same thing with the tranny, yup. I'd also use KPro instead of the K20A's ECU just for the sake of being able to plug into OBDII emissions scanners.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">because i use to have a RSX-s untill i flipped it .so i really never had to worrie about swaps</TD></TR></TABLE>
Welcome to the world of having a sweet car that's just aching for a faster motor.
Old Jul 24, 2006 | 06:09 PM
Ep3_boI's Avatar
Thanx for the information..this should make the swap a lot easier. ill put sum pics up after we get everything perfect
JPerkMr954
Transmission & Drivetrain
10
Feb 10, 2011 02:19 PM
stehigs321
12
Oct 3, 2007 09:39 AM
starbury
Feb 15, 2005 09:58 AM
UnderGroundConcepTS
Oct 2, 2004 02:22 PM
Ekco
Jun 13, 2002 12:36 PM
