Shifter cradle not supporting shifter and shift knob??
Old 09-12-2007, 10:50 AM
stehigs321's Avatar
Default Shifter cradle not supporting shifter and shift ****??
Hey guys, I have a 96 civic with 98 b18c1. Recently my shifter would fall when i was in the lower gears, i.e. 2nd, 4th, reverse. Not it has begun falling when in nuetral and sometimes when in 1st, 3rd, and 5th. I picked up an adjustable short shifter from a friend when i did the swap. The fulcrum of the shifter is like a plastic ball which allows the shifter length to be adjusted. My question is, do you think the plastic ball joint is worn? How can i go about getting a replacment cradle or cup for the shifter? please let me know asap, sucks driving like this. thanks for all the help HT
Old 09-12-2007, 11:27 AM
instrument's Avatar
a plastic ball on your shifter?
i've never seen plastic used in a shifter, do you have a picture?
i'm sure this is the issue though, have you visually inspected it?
Old 09-12-2007, 12:31 PM
stehigs321's Avatar
Default Re: (instrument)
I have not yet been able to give it a look. I want to say it is a pace setter shifter. like this one here.... http://www.amazon.com/exec/obi...nosim any other suggestions???
Old 09-12-2007, 12:33 PM
stehigs321's Avatar
Default Re: (stehigs321)
The ball that adjusts is plastic i am pretty sure. it screws up and down depending on your desired throw.
Old 09-12-2007, 03:08 PM
stehigs321's Avatar
please help guys. do i need a new things that accepts the ball joint of the shifter or what??
Old 09-13-2007, 07:13 AM
stehigs321's Avatar
anyone else have this issue??
Old 09-13-2007, 07:37 AM
pork's Avatar
I'm having a hard to understanding what's going on, but it seems as tho your problem is that you need to tighten the thing that holds the ball of the shifter to the shift linkage. don't over tighten tho or it will be very hard to get it in gear.
Old 09-13-2007, 07:43 PM
stehigs321's Avatar
Default Re: (pork)
how do you go about tightening this??
Old 09-18-2007, 11:03 AM
stehigs321's Avatar
do you think i need to remove the interior of the car to do this or just be able to get underneath?
Old 09-22-2007, 04:37 AM
stehigs321's Avatar
anyone??
Old 09-27-2007, 07:45 AM
stehigs321's Avatar
still need help with this
Old 09-27-2007, 08:20 AM
Bounty - € 8,000,000
.Radical_Edward.'s Avatar
Was the car swapped from automatic to manual?
I know mine is a little too far back.
Old 10-03-2007, 09:39 AM
stehigs321's Avatar
Default Re: (.Radical_Edward.)
The car is swapped but the shifter position is good. The ball where the fulcrum point is of the shifter falls through the cradle type object in the linkage. any help would be appreciated. still driving around holding up my shifter to be able to shift.
JDM_rolex
01-01-2014 07:16 PM
Boostn B20
07-12-2011 07:35 PM
gameknb
06-11-2005 07:32 AM
IntegraBoy04
08-13-2003 12:40 AM
Ekco
06-13-2002 12:36 PM
Quick Reply: Shifter cradle not supporting shifter and shift knob??
