Car Loses Power when i hit the gas!!!
Old Jul 13, 2006 | 02:00 PM
docctorwho's Avatar
Default Car Loses Power when i hit the gas!!!
I bought the car from the guy who couldn't find the problem!!! there is new plugs wires roter cap fuel pump and filter...air filter oil oil filter... is really bad going up hills wont take any more than an idle speed. Thought it was the alt but no such luch the plug was off of it and when i put it on the car did run better for a time...it was real hot today but i dont know...wouldn't start for a while today either...its a 1990 integra gs...
Im thinking the fuel injectors...but if you all can think of something to check let me know...
The check engin light was on for a bit but no longer on now...
Also vacuum Strong n steady
and compression tight too
Auhhhhh
Help!!!
Old Jul 13, 2006 | 02:48 PM
Dogginator's Avatar
Daisy... Daisy...
Default Re: Car Loses Power when i hit the gas!!! (docctorwho)
Look in the FAQ for information on pulling the CEL codes.
Old Jul 13, 2006 | 03:01 PM
numberone's Avatar
Try the TPS sensor.
Old Jul 13, 2006 | 03:10 PM
Chubakon's Avatar
Default Re: Car Loses Power when i hit the gas!!! (numberone)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by numberone &raquo;</TD></TR><TR><TD CLASS="quote">Try the TPS sensor.</TD></TR></TABLE>
i have a question about the TPS sensor.
one of the screw to hold the TPS broke off and now there's only one screw left holding it in the throttle body, and it has a leak there, is there any ways to fix it?
Old Jul 13, 2006 | 05:48 PM
docctorwho's Avatar
Default Re: Car Loses Power when i hit the gas!!! (Chubakon)
What is a good way to check the tps???
Old Jul 16, 2006 | 09:04 AM
docctorwho's Avatar
AFTER CHECKING MANY THINGS I BELEIVE THAT MAYBE THE CARS TIMING IS OFF JUST A TOOTH... WHAT DO YOU ALL THINK ABOUT THIS BEING THE PROBBLEM!!!
98greensi
Jul 23, 2011 07:26 AM
viciousvisionslarry
Apr 3, 2011 02:13 PM
SupraRXZ
10
Dec 4, 2006 06:03 PM
92greensr
Jan 17, 2004 09:53 AM
BDTURBO
Feb 25, 2003 04:36 PM
