FULLY BUILDING D16Z6
Old Jul 12, 2006 | 10:25 PM
rsdracing's Avatar
Default FULLY BUILDING D16Z6
WHAT ELSE CAN U GET TO FULY BUILD A D16Z6 ENGINE, SO FAR I KNO OF HEADERS, INTAKE,CAMS,INJECTORS, ANYTHING ESLE WOULD BE GREAT!!
Old Jul 12, 2006 | 10:55 PM
Voyage34's Avatar
Default Re: FULLY BUILDING D16Z6 (rsdracing)
n/a or turbo?
na/ you can do high comp pistons, headwork, new valvetrain etc in addition to what you mentioned
Old Jul 12, 2006 | 10:59 PM
PRDM's Avatar
maybe this will help you out for n/a... its in the FAQ
https://honda-tech.com/zerothread?id=335078
if you want to find out some more, d-series.org has some good info on making power out of a d16..
Old Jul 12, 2006 | 11:02 PM
jdm_sir2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rsdracing &raquo;</TD></TR><TR><TD CLASS="quote">WHAT ELSE CAN U GET TO FULY BUILD A D16Z6 ENGINE, SO FAR I KNO OF HEADERS, INTAKE,CAMS,INJECTORS, ANYTHING ESLE WOULD BE GREAT!!</TD></TR></TABLE>
Fully built engine you would have to get the following done
Intake/Header/Exhaust/Throttle Body/Intake Manifold/Cams/Cam Gears/Valves and Valve Springs and Retainers, Head Work Port and Polish/Injectors/Fuel pump/Forged Pistons/Forged Rods/ Sleeved Block/ Blueprinted and Balance Crankshaft/and some really good engine management system and lots of hours of dyno tuning and track testing and tuning....
Old Jul 13, 2006 | 05:46 AM
Everyones Hero's Avatar
Default Re: FULLY BUILDING D16Z6 (jdm_sir2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdm_sir2 &raquo;</TD></TR><TR><TD CLASS="quote">Fully built engine you would have to get the following done
Intake/Header/Exhaust/Throttle Body/Intake Manifold/Cams/Cam Gears/Valves and Valve Springs and Retainers, Head Work Port and Polish/Injectors/Fuel pump/Forged Pistons/Forged Rods/ Sleeved Block/ Blueprinted and Balance Crankshaft/and some really good engine management system and lots of hours of dyno tuning and track testing and tuning....</TD></TR></TABLE>
Good man.
For all the money you'd dump into that Z6 you could get a turbo kit or a swap and make more power.
We're about to put together a fully built H22 powered hatch. Whoot!
Old Jul 13, 2006 | 05:57 AM
LowSlow93Sol's Avatar
Default Re: FULLY BUILDING D16Z6 (Everyones Hero)
^ ^ ^ He is right. There is really no point in building an all motor D series. (unless you have money to burn) Go turbo.
Old Jul 13, 2006 | 10:11 AM
jdm_sir2's Avatar
Default Re: FULLY BUILDING D16Z6 (onefast93sol)
Either way to be fast on a D-series you are either running some sort of Forced Induction! But still it would be really wise to build the more so it can take more abuse and make more power cuz the engine I think will only hold to about 230-250hp before you start to break stuff....if you go turbo the most basic things to do is Piston/Rods/and get the block posted and some ARP pistons because D-series have a tendency to lift the head under high pressure also spun rod bearing is another issue so some better rod bearing would make life alot nicer!
Old Jul 13, 2006 | 10:17 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdm_sir2 &raquo;</TD></TR><TR><TD CLASS="quote">spun rod bearing is another issue so some better rod bearing would make life alot nicer!</TD></TR></TABLE>
Yes, the D series have a tendency to spin bearings at high rpms. Best thing to do about that is make sure that your rods come with the ARP 2000 hardware or are rated to rev high.
There arn't any bearings better than OEM.
Old Jul 13, 2006 | 10:27 AM
jdm_sir2's Avatar
Aren't ACL bearing really good?
Old Jul 13, 2006 | 10:28 AM
Default Re: (jdm_sir2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdm_sir2 &raquo;</TD></TR><TR><TD CLASS="quote">Aren't ACL bearing really good?</TD></TR></TABLE>
They're good, but not as good as OEM. They're just cheaper.
I forgot which sponsor I had talked to, but that's basically what they told me.
Curlybandit
Nov 14, 2016 01:17 PM
battlecrxT
Aug 19, 2011 09:39 AM
mikeh74
Nov 15, 2008 03:52 PM
CivicLxFL
Feb 8, 2007 12:37 PM
gazi2006
Jun 8, 2006 12:38 AM
