HELP bearing!!
Old Jul 12, 2006 | 08:39 AM
coupedragracing's Avatar
Default HELP bearing!!
are the d15 bearing the same to a d16 bearing that are around the crank. stock ones.. question is could i swap bearing out. on the block.
jose
Old Jul 12, 2006 | 08:40 AM
poison's Avatar
Default Re: HELP bearing!! (coupedragracing)
to be honest. I would not recommend it. doesn't matter if they are compatible with each other or not. I would correspond with what color codes you have on the block, and get new bearings.
Old Jul 12, 2006 | 08:50 AM
Default Re: HELP bearing!! (poison)
hmm i see how much are bearing some o.e.m. ones.
Fishy_hondaman
Engine Machining & Assembly
Sep 18, 2016 10:05 PM
ziggy3784
Apr 30, 2009 07:48 AM
MARVNVRAM
Dec 19, 2007 05:26 AM
THEUSED
Mar 21, 2005 11:06 AM
carblegal
Jul 2, 2003 07:32 PM
