Honda S2000 Honda S2000
Oil & Oil Filters
Old Jul 11, 2006 | 09:08 AM
Kingsta18's Avatar
Default Oil & Oil Filters
Hey everyone, I did a search both here and on s2ki and I could not find anything newer than 2003.
What filters and Oil are you currently running in your s2k?
I personally am thinking of running Royal Purple Oil, but I don't know what filter to go with.
Recommendations welcome
Old Jul 11, 2006 | 09:49 AM
djdorifto's Avatar
Default Re: Oil & Oil Filters (Kingsta18)
just did a engine, tranny, and diff with Amsoil oil and their oil filter. Awesome stuff I highly it recommend.
Old Jul 11, 2006 | 09:57 AM
S2000Forsale's Avatar
mobil 1 full synthetic ( for oil )
Old Jul 11, 2006 | 11:05 AM
mellowhead's Avatar
Default Re: (S2000Forsale)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by S2000Forsale &raquo;</TD></TR><TR><TD CLASS="quote">mobil 1 full synthetic ( for oil )</TD></TR></TABLE>
Isn't ALL Mobil1 Synthetic....!
Old Jul 11, 2006 | 11:11 AM
iam7head's Avatar
Default Re: (mellowhead)
Valvoline Maxlife
bosch filte/oem filter
Old Jul 11, 2006 | 11:25 AM
aus s2k's Avatar
I'm using Mobil1 synthetic and an OEM filter.
Old Jul 11, 2006 | 11:51 AM
Mr. Projekt's Avatar
* B A N N E D *
Default Re: Oil & Oil Filters (aus s2k)
Royal Purple, AMSOIL, or Mobil 1 oil, AMSOIL filter.
Old Jul 11, 2006 | 01:43 PM
ITRbroham's Avatar
shit post warrior
Default Re: Oil & Oil Filters (FR-MOB: Projekt)
Castrol Syntec 5w-40/10w-30 or Motul 5w-40 and Honda PCM filter.
Edited
Old Jul 11, 2006 | 01:46 PM
* B A N N E D *
Default Re: Oil & Oil Filters (ITRbroham)
40? I'm on 10-30 or 5-30.
Old Jul 11, 2006 | 01:55 PM
Kingsta18's Avatar
The book said ambient temp from -20 to +100 F for 5w-40. Maybe he lives somewhere really cold ?
Old Jul 11, 2006 | 01:58 PM
* B A N N E D *
He's in SoCal like I am, that's why I wondered.
Old Jul 11, 2006 | 02:09 PM
ITRbroham's Avatar
shit post warrior
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kingsta18 &raquo;</TD></TR><TR><TD CLASS="quote">The book said ambient temp from -20 to +100 F for 5w-40. Maybe he lives somewhere really cold ?</TD></TR></TABLE>
Nope, that's what I use when I track my S2K. Most Honda tuners recommend this viscosity for track duties.
Old Jul 11, 2006 | 02:10 PM
* B A N N E D *
Really? Haven't heard that. What about windage losses with the higher warm viscosity?
Old Jul 11, 2006 | 02:15 PM
Kingsta18's Avatar
yea that^
Old Jul 11, 2006 | 02:20 PM
ITRbroham's Avatar
shit post warrior
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FR-MOB: Projekt &raquo;</TD></TR><TR><TD CLASS="quote">Really? Haven't heard that. What about windage losses with the higher warm viscosity?</TD></TR></TABLE>
Yup. I've been told that it's beneficial because the higher warm viscosity will sheer to a lower one under the high temps asscociated with driving on a track/circuit. So of course you can infer what would happen with a lower warm viscosity. I've never really heard anything about windage losses from a higher warm viscosity.:shrugs:
Old Jul 11, 2006 | 02:26 PM
* B A N N E D *
From what I know with variable weight oils, take 5-30 for example, the oil starts at the "5" and gets thicker as temperature rises, to the "30". Under track condition, wouldn't it "shear" to a higher viscosity?
Old Jul 11, 2006 | 02:31 PM
ITRbroham's Avatar
shit post warrior
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FR-MOB: Projekt &raquo;</TD></TR><TR><TD CLASS="quote">From what I know with variable weight oils, take 5-30 for example, the oil starts at the "5" and gets thicker as temperature rises, to the "30". Under track condition, wouldn't it "shear" to a higher viscosity?</TD></TR></TABLE>
I'm no expert on motor oils.
Old Jul 11, 2006 | 02:38 PM
* B A N N E D *
Booooooooooooooooooooo.
You can't start a discussion then pull that crap.
Old Jul 11, 2006 | 03:00 PM
ITRbroham's Avatar
shit post warrior
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FR-MOB: Projekt &raquo;</TD></TR><TR><TD CLASS="quote">Booooooooooooooooooooo.
You can't start a discussion then pull that crap.</TD></TR></TABLE>
Okay, you're right.
Wouldn't is also depend on the additive(s) and the base. Different manufacturers use different additives and bases. A petroleum base as opposed to and ester base?
Old Jul 11, 2006 | 03:37 PM
* B A N N E D *
Pure ester-based oils are usually single weight. Multi-weight oils like ours are usually ester-based with additives, semi-synthetic, or full synthetic. The idea behind that AFAIK is to have low the viscosity when the engine is cold for easy startup, then have the oil thicken up or maintain its viscosity as the temperature rises.
This still doesn't mean the oil will be thicker overall on a fully warmed motor. The "5/10" viscosity will be too thin as the motor is fully warmed up, hence the need for it to thicken to "30"
Still, viscosity ratings are temperature based. A "30" at 300degrees will be thinner than a "5" at room temp.
Back to your point:
If the additives are designed to thicken the motor oil, the "40" would be even more viscous at track temps. Higher temp &gt; higher viscosity?
Til next time Batman!
Old Jul 11, 2006 | 03:59 PM
ITRbroham's Avatar
shit post warrior
Back to your point:
If the additives are designed to thicken the motor oil, the "40" would be even more viscous at track temps. Higher temp &gt; higher viscosity?</TD></TR></TABLE>
Isn't that what you want for a motor that is being revved continously up to 8-9k rpm like the F-series engines?
Old Jul 11, 2006 | 04:12 PM
* B A N N E D *
I would think that keeping it on 10-30 would help high-rpm responsiveness.
happynoodleboy
Feb 20, 2008 06:34 PM
lazykiwi
Dec 26, 2005 09:38 PM
Floyd
Sep 23, 2003 07:08 AM
Sohc Driver
32
Jul 15, 2003 02:46 PM
dclub01
May 1, 2003 03:22 PM
