do 5th gens have factory oil coolers?
Old Jul 10, 2006 | 09:46 PM
BB6racer's Avatar
Default do 5th gens have factory oil coolers?
i was looking at some thread in the type-r forum and i didn't know hondas came with factory oil coolers ! thats so cool (did you get that little play on words?)!!!! i tried searching but haven't found anything, so does anyone know if USDM preludes came with factory oil coolers?
Old Jul 10, 2006 | 09:54 PM
Mykizism's Avatar
Default Re: do 5th gens have factory oil coolers? (BB6racer)
yes
Old Jul 10, 2006 | 10:08 PM
petern101's Avatar
Default Re: do 5th gens have factory oil coolers? (Mykizism)
whenever you take off the oil filter.
right there is the oil cooler, basically the oil filter sits right ontop of the oil cooler
Old Jul 11, 2006 | 04:36 AM
integra15's Avatar
Default Re: do 5th gens have factory oil coolers? (petern101)
It is not a very effective one, but they are in there.
Old Jul 11, 2006 | 07:22 AM
petern101's Avatar
Default Re: do 5th gens have factory oil coolers? (integra15)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integra15 &raquo;</TD></TR><TR><TD CLASS="quote">It is not a very effective one, but they are in there.</TD></TR></TABLE>
i guess if you are running turbo / fi it might not be
but for everyone else, it works just fine.
Old Jul 11, 2006 | 07:33 AM
577HondaPrelude's Avatar
the stock one does not work too good on a hot day 85f+ and your on a race track for 20min+ going all out. You will get oil temps up to 260f, even though water temp stays at 220f. Other than that it works great, you will never get it that hot driving around town no matter how hard you try, so unless your tracking the car or have turbo then the OEM cooler is good enough.
Old Jul 11, 2006 | 08:13 AM
soundbomber's Avatar
Default Re: do 5th gens have factory oil coolers? (577HondaPrelude)
is it possible to remove the factory oil cooler in place of a sandwich adapter and then run inward and outward bound lines to a setrab or similar oil cooler?
Old Jul 11, 2006 | 09:53 AM
Default Re: do 5th gens have factory oil coolers? (soundbomber)
yes you can get a sandwich adapter, but there is no need to remove the factory cooler. you can just replace the oil filter with the sandwich plate and run an external oil cooler with the OEM internal oil cooler still there. you then relocate the oil filter, and you can even run a bigger filter if you mount the filter holder in a place that has more room than the stock location.
This is the kit I'm installing before next race:
http://www.mfactoryhk.com/prod...20Kit
Great deal and it comes with every thing you need.
Old Jul 11, 2006 | 11:54 AM
BB6racer's Avatar
ok thanks. now i have a couple more questions:
wouldn't a bigger oil filter lower our oil pressure?
could you use an aftermarket oil cooler and run new lines to the factory piece before the oil filter? or would you still need a sandwich adapter and a kit similar to the one in the link above?
Old Jul 11, 2006 | 01:18 PM
Default Re: (BB6racer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">wouldn't a bigger oil filter lower our oil pressure?</TD></TR></TABLE>
No, they typically have less drop in oil pressure across the filter. Same filter media as the smaller size, just more surface area for the oil to pass though.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">could you use an aftermarket oil cooler and run new lines to the factory piece before the oil filter? or would you still need a sandwich adapter and a kit similar to the one in the link above?</TD></TR></TABLE>
The factory cooler is connected directly to the engine block so there isn't any oil lines running to it, it just lines up with oil ports on the block, and the other side is were the filter screws into. Our cars don't have any external oil lines at all, unless you add them.
Old Jul 11, 2006 | 05:10 PM
BB6racer's Avatar
thanks 577, but let me explain what i meant in my last post. look at the pic in the link below and find part 17. it has 2 solid lines connecting to it that i think go to the oil cooler. i want to connect 2 stainless teel braided lines to those, and run an aftermarket external oil cooler mounted in the front bumper. would that idea work? is part #17 even the factory oil cooler fluid sender?
Old Jul 11, 2006 | 05:47 PM
117's Avatar
117
I don't see a link in your post, but if you're talking about the two lines that go from the oil cooler to the engine, they're coolant lines, not oil lines. The stock oil cooler is an oil-to-water oil cooler. The oil flows from the block into the cooler and then into the filter. There are no oil lines in the cooler.
I removed the oil cooler on my H22 and used a thermostatic Mocal sandwich plate with a huge Mocal cooler. I don't see a reason to keep it, and I wanted to eliminate any unnecessary fluid lines in the engine.
Old Jul 11, 2006 | 07:23 PM
BB6racer's Avatar
Default Re: (117)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 117 &raquo;</TD></TR><TR><TD CLASS="quote">I don't see a link in your post</TD></TR></TABLE>
OMG i'm emberrased. i can't believe i forgot that! here you go:
http://www.hondaautomotivepart...AINER
i read your post, and i think you are right. it looks like coolany goes into part #17. i though oil went from #17 to some kind of factory air-to-air cooler. thanks for the help. looks like to will do the sandwich adapter thing
mrlegoman
Aug 4, 2009 10:03 AM
Si Shane
Jul 6, 2006 04:59 PM
Bense
19
May 19, 2006 05:44 PM
Thasty
Honda Motorcycles
Sep 4, 2004 08:28 PM
