front lca joint problem
Old Jul 9, 2006 | 01:28 PM
teddy_dc2's Avatar
Default front lca joint problem
i'm having problems trying to get this joint out so i can get the axle out, i worked around it and got the axle out but now i want it out so i can press in a new one.
it's the very last joint on the hub assembly that holds the lower control arm and hub together. i tried putting a jack under and jacking it, try prying, hammering it and it won't come out, any ideas before i cut it out?
Old Jul 9, 2006 | 04:47 PM
teddy_dc2's Avatar
anyone?
Old Jul 9, 2006 | 06:13 PM
Ls_V_TurboSi's Avatar
Default Re: (teddy_dc2)
if you ever have an issue like this again where you're trying to take the axel out but the hub wont seperate from the lce then just unbolt it up top on the a-arm. The axel will slide out just fine if thats seperated..
My advice on your current problem is hit it harder and with a bigger hammer if you have to.
Old Jul 9, 2006 | 08:10 PM
IN VTEC's Avatar
Default Re: front lca joint problem (teddy_dc2)
You have to have the right kind of hammer and know where to hit it to get it to pop.
You can also jack it up, prop a 1/2" drive ratchet in between the knuckle and the LCA, lower the jack, and step on the caliper. That can also get it to pop fairly easily.
Either method works well.
dumbidea
Aug 20, 2017 07:52 PM
C_Rock77
Aug 27, 2008 11:19 AM
VisualAutoMotoring
Oct 13, 2003 01:38 PM
VisualAutoMotoring
Oct 11, 2003 04:08 PM
munscher
Jun 16, 2003 06:34 PM
