HORRIBLE Sloppy shifter on a GSR Trans... Not the bushings!
Old Jul 9, 2006 | 10:40 AM
USDM EG's Avatar
Default HORRIBLE Sloppy shifter on a GSR Trans... Not the bushings!
Ok, Im posting this for a friend
He has a 99-00 EK Hatch, with a GSR swap in it...
Problem....
Shift is incredibly sloppy... No its not the bushings, its inside the trans.. Back and forth in gear and out of gear
The shaft that hold the linkage moves a **** load... Im wondering what could be broken inside, or for that fact, how it got like that...
I know the trans will have to be dropped, not a big deal, and the trans will need to be opened, not a big deal either..
Old Jul 9, 2006 | 02:59 PM
USDM EG's Avatar
Default Re: HORRIBLE Sloppy shifter on a GSR Trans... Not the bushings! (USDM EG)
help!
Old Jul 9, 2006 | 08:22 PM
robbieshonda's Avatar
get underneath and check the rollpin that hold the linkage to the trans. Ive seen that roll pin not all the way in and it gave it room to play.
Old Jul 9, 2006 | 09:15 PM
ekb16's Avatar
ya check the roll pin....usually if u have play in that area, in each gear it will still feel like ur in netural
Old Jul 10, 2006 | 04:29 AM
USDM EG's Avatar
Default Re: (ekb16)
yeha, its worse than neutral.. i told him to check it... he put a bolt in it instead of the pin i have no idea why.... i was thinking the bolt was really small compared to the size of the pin, that would do it too...
Old Jul 10, 2006 | 05:30 AM
JDM knowledge's Avatar
Default Re: (USDM EG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by USDM EG &raquo;</TD></TR><TR><TD CLASS="quote">yeha, its worse than neutral.. i told him to check it... he put a bolt in it instead of the pin i have no idea why.... i was thinking the bolt was really small compared to the size of the pin, that would do it too...</TD></TR></TABLE>
well i think you just answered your own question. Get the rollpin it doesnt break the bank.
Old Jul 10, 2006 | 05:40 AM
USDM EG's Avatar
Default Re: (JDM knowledge)
10-4.. thank you all..
Old Jul 10, 2006 | 12:35 PM
No problem
Old Jul 11, 2006 | 04:41 AM
USDM EG's Avatar
Default Re: (robbieshonda)
yep, that was the problem.. I didnt look at the linkage, they lowered the car b4 i got there, so didnt check... but its all good now.. thank you h-t...
PS. i cant beleive i got a problem/question solved on this forum without someone telling me to search...
after a few years of being on the site, this is a first
Old Jul 11, 2006 | 06:11 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by USDM EG &raquo;</TD></TR><TR><TD CLASS="quote">yep, that was the problem.. I didnt look at the linkage, they lowered the car b4 i got there, so didnt check... but its all good now.. thank you h-t...
after a few years of being on the site, this is a first</TD></TR></TABLE>
*search* lmao, sorry.
Old Jul 13, 2006 | 12:36 AM
HondanaticR's Avatar
the up and down pin/ rollin pin is only 50 cent at dealership. a bolt will cause it to be sloppy
Rolo30
Transmission & Drivetrain
12
Apr 25, 2009 03:19 PM
whats_A_eh2
Mar 28, 2008 03:40 PM
miguel329
Feb 4, 2008 11:55 PM
oni3
Jul 23, 2005 07:26 PM
one slow coupe
Jun 28, 2005 04:10 PM
