HORRIBLE Sloppy shifter on a GSR Trans... Not the bushings!
Ok, Im posting this for a friend
He has a 99-00 EK Hatch, with a GSR swap in it... Problem.... Shift is incredibly sloppy... No its not the bushings, its inside the trans.. Back and forth in gear and out of gear The shaft that hold the linkage moves a shit load... Im wondering what could be broken inside, or for that fact, how it got like that... I know the trans will have to be dropped, not a big deal, and the trans will need to be opened, not a big deal either.. |
Re: HORRIBLE Sloppy shifter on a GSR Trans... Not the bushings! (USDM EG)
help!
get underneath and check the rollpin that hold the linkage to the trans. Ive seen that roll pin not all the way in and it gave it room to play.
ya check the roll pin....usually if u have play in that area, in each gear it will still feel like ur in netural
Re: (ekb16)
yeha, its worse than neutral.. i told him to check it... he put a bolt in it instead of the pin http://images.honda-tech.com/set1//smile/emcrook.gif i have no idea why.... i was thinking the bolt was really small compared to the size of the pin, that would do it too...
Re: (USDM EG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by USDM EG »</TD></TR><TR><TD CLASS="quote">yeha, its worse than neutral.. i told him to check it... he put a bolt in it instead of the pin http://images.honda-tech.com/set1//smile/emcrook.gif i have no idea why.... i was thinking the bolt was really small compared to the size of the pin, that would do it too...</TD></TR></TABLE>
well i think you just answered your own question. Get the rollpin it doesnt break the bank. |
Re: (JDM knowledge)
10-4.. thank you all..
Re: (USDM EG)
No problem
Re: (robbieshonda)
yep, that was the problem.. I didnt look at the linkage, they lowered the car b4 i got there, so didnt check... but its all good now.. thank you h-t...
PS. i cant beleive i got a problem/question solved on this forum without someone telling me to search... https://honda-tech.com/forums/images/smilies/emthup.gif after a few years of being on the site, this is a first |
Re: (USDM EG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by USDM EG »</TD></TR><TR><TD CLASS="quote">yep, that was the problem.. I didnt look at the linkage, they lowered the car b4 i got there, so didnt check... but its all good now.. thank you h-t...
PS. i cant beleive i got a problem/question solved on this forum without someone telling me to search... https://honda-tech.com/forums/images/smilies/emthup.gif after a few years of being on the site, this is a first</TD></TR></TABLE> *search* lmao, sorry. |
the up and down pin/ rollin pin is only 50 cent at dealership. a bolt will cause it to be sloppy
