ls block gaurd or not ?????
hey guys im about to boost my ls and i wanted to know if i should use a block gaurd.....i heared that they give u more problems wat do u guys think let me know thnx...
What setup are you planning on running?
I would say no to teh block guard. Its all about the tune and how you treat the car as to how long it lasts.
cool dats wat i figured...lets see now 450 dsms/255 fuel pump/2 1/2 in intercooler piping/3 inch exhaust/vaccum manifold/oil sandwhich plate for feed & pressure/t3 48/42 garrett/xternal wastgate w/ 8 psi spring/92-95 civic koyo radiator/turboedit/arp 11mm head studds/new thicker head gasket/timing gears alluminum pulleys/stage 2 clutch/and stage 1 cv joints/3 bar map sensor/dual stage boost controller.
B18C1CYA
May 30, 2004 07:14 AM
