JDM Cluster in 92 EG..DX
Old Jul 7, 2006 | 10:17 PM
crxcel's Avatar
Default JDM Cluster in 92 EG..DX
Just installed it tonight and can get everything to work but my tach. I have a green wire on the back that does not seem to have a place to go is this related to tach? My car didnt hav Tach originally so i figured the yellow 3 wire plug would be my tach wires, but any help would be great
Old Jul 7, 2006 | 10:37 PM
JCL's Avatar
JCL
the dx didnt come with a tach on the cluster but it still had the tach wiring.. i did this as well to my dx and it is working fine..
Old Jul 8, 2006 | 05:41 AM
crxcel's Avatar
Default Re: (JCL)
did yours have a green wire? it was seperated from the 3 plugs and was sodered to the back of the board on the heat/fuel side of the cluster. If so what wire do i hook it too on my harness? Or is there a wire that is hiding?
Old Jul 8, 2006 | 06:49 AM
G2 Speed's Avatar
Default Re: (crxcel)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxcel &raquo;</TD></TR><TR><TD CLASS="quote">did yours have a green wire? it was seperated from the 3 plugs and was sodered to the back of the board on the heat/fuel side of the cluster. If so what wire do i hook it too on my harness? Or is there a wire that is hiding?</TD></TR></TABLE>
It should be a direct, nothing "should" be hiding. Could it be possible the tach is busted?
Did you just buy this?
Old Jul 8, 2006 | 08:37 AM
baozer's Avatar
Default Re: JDM Cluster in 92 EG..DX (crxcel)
thats koooo
Old Jul 8, 2006 | 09:49 AM
philosofy1's Avatar
everything should already be on the harness. just a plug - n - play. if the tach is not working, then it's the tach, not the wiring.
Old Jul 8, 2006 | 10:39 AM
93egryda's Avatar
yes it is the whole problem get the green plug plugged in and you will have the rpm.
Old Jul 8, 2006 | 11:15 AM
crxcel's Avatar
Default Re: JDM Cluster in 92 EG..DX (93egryda)
I have all 3 plugs plugged in, but there is anotyher green wire all by itself that looks factory sodered to the back of the cluster..I will takes some pics and put them up on monday. And yes i just bought the cluster. Any fuses that are for the Tach?. All the other lights/guages work fine
kseriesdreams
Dec 26, 2010 04:56 PM
240sx crazy
Honda Civic (2001 - 2005)
Mar 18, 2008 05:16 AM
NastyEJ1
Jul 5, 2006 03:46 PM
joecivic93
Jan 6, 2004 10:07 PM
B19CivicHB
Oct 31, 2001 09:53 AM
