radio not getting power?
Well I have done like my 20th radio in a car, and everything went perfect until, I put it back together and tried to turn it on and nothing.... So I went back to trouble shoot and turned the car off and checked the wires for the one with power (memory wire) And found it. Then I turned the car on and put the tester up to the power wire and.... nothing. It had the original wiring harness plug however I cut it out and soldered and spliced in the new harness for the new cd player. I dont know if it worked prior, because there wasnt one in there b4 All the wires look good does anybody have any ideas?
I know you said you've done 20 players, but did you forget something retardedly obvious, like forgetting to plug in the antenna.
Its always the obvious stuff that gets the best of the experienced people
Ur 4sure The CD player Works?, and Check The Power & Ground, im betting its something super obivious, but hey, it happens to the best of us, even chuck norris.
