wiring?
Old Feb 18, 2008 | 12:41 PM
eskerley's Avatar
Default wiring?
i went to put an alpine cd playing into my 94 civic dx hatch and when i connected all the matching wires up the cd player it wouldn't turn on. When i connect both the yellow and red wire coming from the cd player to the red wire coming from the car, the cd player works, but if i do it the "right" way it doesn't. any ideas?
Old Feb 18, 2008 | 03:48 PM
JSPECSIR's Avatar
Default Re: wiring? (eskerley)
blown fuse maybe?
Old Feb 18, 2008 | 04:45 PM
Untamed_Hatred's Avatar
did you use a plug and polay harness or did you cut the one out of the car??
Old Feb 18, 2008 | 05:01 PM
dj-t's Avatar
so you hooked up the wires color for color so I'll assume that you have a harness.
check the back up fuse in the engine compartment or the radio fuse under the driver dash and see if it is blown.
Old Feb 19, 2008 | 10:44 AM
CivicPride97's Avatar
Did you cut the factory plug? If so you cant wire the radio harness to the car harness by color to color. If its the plug and play the check fuses......
Old Feb 29, 2008 | 10:23 AM
efmike84's Avatar
check to make sure that you have power to both wires when the key is on. you are not geting power from one of the wires thats why it only works when they are together.
Old Feb 29, 2008 | 08:31 PM
94_DC4's Avatar
Your problem is with the accessory turn on. Test the radio fuse that is in the fusebox under the dash and the back up fuse that is in the fusebox in the engine bay. Also test the fuse on the actual radio.
Old Feb 29, 2008 | 08:44 PM
wrx-killer-Sti-eater's Avatar
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
Default Re: wiring? (94_DC4)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94_DC4 &raquo;</TD></TR><TR><TD CLASS="quote">Your problem is with the accessory turn on. Test the radio fuse that is in the fusebox under the dash and the back up fuse that is in the fusebox in the engine bay. Also test the fuse on the actual radio. </TD></TR></TABLE>
backby special appreance
PainInMyCivic
Audio / Security / Video
Jan 21, 2014 06:09 PM
tyler100
Jan 5, 2008 02:39 PM
civicgsr116
Nov 8, 2007 01:01 PM
SupaFly_Honda
Dec 18, 2006 10:15 AM
90jdmcrxdude
Jul 9, 2006 08:44 PM
