my engine shuts off below 1000 rpm.. what could be the problem be?
i have an '02 accord 6 cyl. with 74 k miles on it.. my car will start but will die after it drops below 1000 prm.. unless i keep revving it any idea what it can be?
look under the hood, check all the sensors and make sure nothing is disconnected, I'd check the MAP sensor first. I take it you're not throwing a CEL.
There's too many possibilitys to determine what it could be, anything from your car battery to a jacked up sensor, so you'll need to explain exactly when it dies and different variations.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Accord2k-Hybrid »</TD></TR><TR><TD CLASS="quote">look under the hood, check all the sensors and make sure nothing is disconnected, I'd check the MAP sensor first. I take it you're not throwing a CEL.
There's too many possibilitys to determine what it could be, anything from your car battery to a jacked up sensor, so you'll need to explain exactly when it dies and different variations.</TD></TR></TABLE>
umm.. that's pretty much umm it.. i start it.. and it dies below 1500 rpm. it won't stay on.. *sighs.. it's not the battery because it was jsut replaced umm 2 days before it happened.. not sensors either.. idle control valve.. maybe.. idle plates.. dunno..
Chiovnidca
May 7, 2013 12:21 PM
