oil in combustion chamber!!!!!!!!
Old Jul 7, 2006 | 05:13 PM
djgodspeed89's Avatar
Default oil in combustion chamber!!!!!!!!
what could be the reason for oil on the number one cylinder but none of the others? have driven it and runs so poorly. could it be a timing issue or a seal/gasket problem?
Old Jul 7, 2006 | 05:23 PM
SVOboy's Avatar
Could be blown rings or a chipped valve or something like that, run a compression test.
Old Jul 7, 2006 | 05:28 PM
Default Re: (SVOboy)
did compression tests and all cylinders are between 140 and 150 on a zc dohc
Old Jul 7, 2006 | 05:37 PM
Got_soy's Avatar
Default Re: (djgodspeed89)
rings is my guess. comp should be hingher than that
192 according to the manual and no lower than 135.
Old Jul 7, 2006 | 06:13 PM
Default Re: (Got_soy)
ok just got out my timing gun and i am only seeing the one mark that is by itself on thee crankshaft pully not the three like im sure is supposed to be if that helps with anything
Old Jul 7, 2006 | 06:38 PM
anyone else got any ideas?////bump....
Old Jul 7, 2006 | 08:50 PM
nappyroots827's Avatar
valve stem seal
alchemyst6
18
Jul 21, 2011 10:08 AM
Jamarquis
Jul 3, 2008 11:33 AM
RedGSR1994
Nov 21, 2006 05:10 PM
red teg
Oct 9, 2005 03:33 PM
AMChev
Sep 15, 2002 10:26 AM
