Burning Oil 1 qt per 500 mi. good compression. - Honda-Tech - Honda Forum Discussion
Old 03-28-2011, 06:59 PM   #1
Default Burning Oil 1 qt per 500 mi. good compression.
Long time lurker, first time poster.
I have a 2000 Civic SI that burns about 1 quart of oil every 500 miles. No leaks. From all the research I've done it appears that it is either the oil control rings or the valve stem seals. Here are my numbers from the compression test:
Cylinder Dry Wet
1 170 220
2 180 230
3 185 220
4 180 220
Leakdown test done dry
1 16%
2 7%
3 4%
4 7%
According to Honda 185 psi is normal. What are you guys getting with your tests? I haven't seen any smoke. I am stumped.
alchemyst6 is offline   Reply With Quote
Old 03-28-2011, 07:06 PM   #2
Default Re: Burning Oil 1 qt per 500 mi. good compression.
Where is cylinder 1 losing compression?
Former User is offline   Reply With Quote
Old 03-28-2011, 07:15 PM   #3
I couldn't determine but my guess would be through the rings. My roomate's car (2000 integra ls) had similar results on the leakdown (1, 10%; 2, 15%; 3 7%; 4, 8%) and it doesn't burn any oil.
Old 03-28-2011, 07:20 PM   #4
Besides worn piston rings, burning oil can also be caused by bad valve stem seals or a bad head gasket.
Is the surface of the engine completely free of oil?
Old 03-28-2011, 07:29 PM   #5
I suspect bad valve stem seals and that will probably be the first thing I change but I'm not sure if that can account for so much oil loss. The compression numbers seem slightly low especially considered against the wet numbers. No oil anywhere on the engine. Oil meticulously changed every 3750 miles with full records. I would say this started around 90,000-100,000 miles (currently 116,000).
On a side note, I adjusted the valve lash at 86,000. There was no oil loss prior to that. It's probably not a cause but someone may have had a similar issue.
Old 03-28-2011, 07:32 PM   #6
longest project ever
lostforawhile's Avatar
Location: on the south side of dixie, 1986 Accord Hatch
you would be surprised how much oil can be lost through those seals, when I replaced the ones on my 86, all the exhaust seals were completely toasted, they have to take a lot and will burn up, every time I stared the car it was like a mosquito fogger, once I put in new seals, it cleared right up, the later model cars have much higher exhaust gas temps and will probably burn them up even faster
lostforawhile is offline   Reply With Quote
Old 03-28-2011, 07:48 PM   #7
I guess I'll have to pull the head and see. I already have the stem seals so I'll probably put them in next week. I really hope that cures the problem. I usually check the oil at the gas station and this consumption problem seemed to present itself pretty quickly.
Old 03-28-2011, 07:55 PM   #8
SOHC_4dr's Avatar
plus 1 for valve stem seals. stay out of vtec to
SOHC_4dr is offline   Reply With Quote
Old 03-28-2011, 07:57 PM   #9
Thank you everyone. Most of my driving is on the highway and I probably hit vtec about 1-2 times a week.
Old 03-28-2011, 08:20 PM   #10
Quote:
Please post pictures of your work.
Old 03-28-2011, 08:54 PM   #11
SOHC_4dr's Avatar
i burn oil only when i hit vtec (i also have a 00 si). when i do i might as well just pull my drain plug out lol i'll lose less oil that way :-/
Old 03-28-2011, 09:05 PM   #12
Its probably oil control rings, they wont show up on a compression because they are not supposed to seal up the combustion chamber, one of two symptoms to determine if it is rings or stem seals oi s when it burns oil, if there is a big cloud of smoke at first start up its stem seal, if it burns during acceleration its control rings, its probably control rings because of the amount of consumption, you can check the pcv system, if its working good it can decrease the it a little
shogee is offline   Reply With Quote
Old 03-28-2011, 09:13 PM   #13
Hondatherdm's Avatar
Quote:
100% agree.
I think its oil rings
Hondatherdm is offline   Reply With Quote
Old 03-29-2011, 05:52 AM   #14
I will post pics. I think I will do both anyways just to cover all my bases.
Old 07-21-2011, 10:42 AM   #15
i lose about 1 liter of oil a week took my civic em1 for compression test at honda and came back 1.205psi 2.200psi 3. 200psi 4. 206psi guy said all in normal levels. so where all my oil going????????? no signs on leak and the odd puff of smoke out the exhaust
davidjames1983 is offline   Reply With Quote
Old 07-21-2011, 10:47 AM   #16
Quote:
Did you read through the posts in this thread?
Is there no engine oil whatsoever on the exterior of you engine? Have you crawled under the car and carefully looked for leaks?
Bad valve stem seals will yield good compression but will cause oil burning.
Old 07-21-2011, 10:52 AM   #17
honda said slight mist on sump, apart from that totally clean
Old 07-21-2011, 11:03 AM   #18
SeanK325's Avatar
scratched cylinder walls not allowing the rings to sit properly?
SeanK325 is offline   Reply With Quote
Old 07-21-2011, 11:08 AM   #19
would that not lose compression though??? plus every time i replace oil every week dont really drive that many miles say 200miles all less
Question about bad rings... cmwright1986 Honda Civic / Del Sol (1992 - 2000) 13 07-29-2010 12:05 AM
Compression Test Results! 94_Teggy Acura Integra 9 03-26-2009 06:15 PM
GSR nightmare, need good advice Phre0nBurn Tech / Misc 4 03-11-2008 10:33 PM
Can bad rings cause misfire? all-mtr-teg All Motor / Naturally Aspirated 26 11-29-2007 09:33 PM
Burning Oil In VTEC, Valve Guides or Rings??? snoochtodanooch Honda Civic / Del Sol (1992 - 2000) 6 07-03-2004 10:07 AM
Tags
06, 2000, 500, bad, burn, burning, burns, miles, oil, prelude, qt, quart, seals, si, tsx, valve
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
  • Ask a Question
Question Title:
Description:
