Which Alternator for poor man's type r
Old Jul 7, 2006 | 04:57 AM
mrossman's Avatar
Default Which Alternator for poor man's type r
going into 93 del sol.
have a gsr bottom end and a 99 civic si head. will be using the del sol wiring harness to keep it obd1
question is
do i use any obd1 b serires alternator or does it have to be a vtec one?
was not able to find this answer in any of the threads
Old Jul 7, 2006 | 05:07 AM
egcivicdelsol's Avatar
Default Re: Which Alternator for poor man's type r (mrossman)
lucky for you... i just ran into those problems... i put an obd2 type r in my del sol http://members.cardomain.com/egcivicdelsol and i converted it to obd1 for my liking. So i used the obd1 single vtec wiring harness... i just went and got an obd1 LS alternator which works fine. So you're going to need a B series Obd1 Alternator, doesnt matter if its rs ls gs gsr or what have you... its just needs to be obd1. The plug on obd2 is way different. i picked mine up at a local wrecking yard for $40.00. Good luck with the swap.
Old Jul 7, 2006 | 08:46 AM
mrossman's Avatar
thanks for all the help
Old Jul 7, 2006 | 07:56 PM
Default Re: (mrossman)
yup n/p.
Old Jun 6, 2007 | 06:45 PM
prestidge81's Avatar
Default Re: (egcivicdelsol)
can it be done for type r ( year 98 ) alternator into civic 92 OBD1?
MadCoder
Jul 18, 2011 05:42 PM
Uniquerootz
Oct 2, 2007 11:40 AM
sparco562
Aug 23, 2007 07:09 PM
white90rexsi
Jan 2, 2007 07:55 PM
egcivicdelsol
Apr 3, 2006 12:35 PM
