turbo kits and block shaving
Old Apr 19, 2002 | 08:30 AM
sickgsr21's Avatar
Default turbo kits and block shaving
I've read a few topics when people put in a drag kti they have to shave 1/2-3/4 of an inch off the block, is this just with hybrids or do you have to shave the engine with all of the drag kits even though its made for the car? do you have to shave the engine with revhard kits to?
Old Apr 19, 2002 | 09:52 AM
ArizonaTurbo's Avatar
Default Re: turbo kits and block shaving (sickgsr21)
Any turbo manifold that places a T04E or T04B compressor housing close to the left side of the block will require cutting of some of the aluminum webing on the block!
Old Apr 19, 2002 | 10:30 AM
sickgsr21's Avatar
Default Re: turbo kits and block shaving (TurbochargedSER)
anyone have pictures of this
Old Apr 19, 2002 | 11:02 AM
intekragsr's Avatar
i will post a pic if i can find it when I get home. Buy yourself a dremel. I had to file that shiet by hand :/
Old Apr 19, 2002 | 12:36 PM
93LSivic's Avatar
Default Re: turbo kits and block shaving (intekragsr)
Or did what i did. A sharp metal grinding bit in an electric drill.
I had to take about 1/2" off of the webbing and I also knocked off one of the tabs to make it easier to run the intake pipe.
Old Apr 19, 2002 | 12:41 PM
Etylorcen's Avatar
Default Re: turbo kits and block shaving (93LSivic)
Sometimes u get lucky and you dont have to shave the block.
Old Apr 19, 2002 | 01:32 PM
Teg4e's Avatar
Default Re: turbo kits and block shaving (Etylorcen)
Yes, from talking to Dave Shih, I learned it's just luck of the draw. But it's much more likely on the fat housing of the E rather than B.
Old Apr 19, 2002 | 01:43 PM
intekragsr's Avatar
Default Re: turbo kits and block shaving (Teg4e)
i dont understand how luck is involved in it
Old Apr 20, 2002 | 11:19 AM
Teg4e's Avatar
B/C although these are imports which have relatively little tolerances for variance in the engine build, there still are some. Remember, we're talking about shaving a 1/4 or 1/2" here. The same turbo may require block shaving on one car and none at all on another.
Old Sep 23, 2002 | 12:36 PM
TurbothisLS's Avatar
can u shave the turbo a little?
Old Sep 23, 2002 | 12:40 PM
MyWhiteCivic's Avatar
With my Drag gen 3 kit on my d16z6 I had to remove one bar that connects the transmission to the engine and I had to heat and twist the downpipe to make it fit. I can't wait to get a 2 1/2" dp
Old Sep 23, 2002 | 01:45 PM
Default Re: turbo kits and block shaving (MyWhiteCivic)
dang man, i bought the drag to avoid all this customizing
crap this sucks
Old Sep 23, 2002 | 03:56 PM
Quick 200k Mile Motor's Avatar
Default Re: turbo kits and block shaving (TurbothisLS)
crap this sucks
ya, I feel ya.
I cant find any manifold that will make everything fit, including A/C.
phauk this, im going with centrifugal SC in place of powersteering! sshhh..
Old Sep 23, 2002 | 04:05 PM
sutrusu's Avatar
Default Re: turbo kits and block shaving (Quick 200k Mile Motor)
no one is gona notice when you sell the car that the block has a notch cut out of it. what's the matter with shaving off a little metal?
Old Sep 23, 2002 | 04:17 PM
ThePunk's Avatar
Default Re: turbo kits and block shaving (sutrusu)
Here's what GSRgrrl and I had to "lightly" trim.
Old Sep 23, 2002 | 08:39 PM
SpeedRacer00-667's Avatar
Default Re: turbo kits and block shaving (ThePunk)
didnt have to shave it on rev hard kit on my gsr, but had to shave it for my DRAG III kit on my R...weird huh?
Old Sep 23, 2002 | 08:47 PM
Mase's Avatar
Default Re: turbo kits and block shaving (SpeedRacer00-667)
on the two turbo installs ive done, we didnt have to shave anything but the fan.
Old Sep 24, 2002 | 01:04 AM
ion_four's Avatar
Default Re: turbo kits and block shaving (CDooMe2)
I had to shave a pretty good bit off of some "webbing" that is around a bolt from the tranny...I was hesitant to shave and didn't take enough, now I noticed I have a slight exhaust leak because the turbo hit the block before the manny sealed all the way
sfwdcrx
Mar 19, 2008 02:33 AM
Muckman
Jan 16, 2004 09:31 AM
Gfunk176
Mar 5, 2003 08:07 PM
philo
Jul 20, 2002 06:40 AM
AllMotorITR
Nov 30, 2001 09:20 AM
