Mini me D16 Timeing Problems please help!
Old Apr 19, 2002 | 07:46 AM
W0oT's Avatar
Banned
Default Mini me D16 Timeing Problems please help!
hey all i'm having trouble w/ the timeing on my d16z6 mini me it's a 91 civic si 1.6 w/ a 94 ex sohc vtec z6 head. well i'm having trouble finding tdc. on the cam sproket that is. there's 3 marks that look like "l" one verticle at 12 o clock and the 2 horizontal at 3 and 9. then there is a arrow on the inner t-belt cover... well what i'm getting to is that i'm not sure where to line what mark to... any idea's???? i just want to make sure timeing is on because i know it's way off. btw i'm running a p28 ecu. and also there's suppose to be a white arrow or dot on my crank pulley but all i can seem to find is a red dot and a "D" stamped on it. any idea's???? i will post pics of the marks and stuff later today but i really want to get this done tonight.
Old Apr 19, 2002 | 09:08 AM
Mugen Dom's Avatar
Default Re: Mini me D16 Timeing Problems please help! (Nismo240sx1)
heres the easiest way to find tdc of the block get a long screw driver and stick it in the #1 spark plug hole and turn the crank to tdc basically when its there leave it and then with eth head the 3 marks are easy there should be a mark that says up that goes up and teh 2 other marks should line up with teh head evenly get a manual it helps alot
Old Apr 19, 2002 | 09:12 AM
W0oT's Avatar
Banned
Default Re: Mini me D16 Timeing Problems please help! (jdmB18hatch)
here's a pic. i think i'm gonna stick a long extension down cyl 1 and turn till it comes to top here's a pic of the cam sprocket that's the next to figure where to line these marks.
Old Apr 19, 2002 | 09:14 AM
W0oT's Avatar
Banned
lol thanks a lot that is what i'm gonna do... i do need to get a manual but i'm gonna spend the dough and get a FSM. but my b16 will be here soon so i'll need one for that motor. this ones comming out.
Old Apr 19, 2002 | 11:41 AM
4gvtec's Avatar
see the mark or line on the bottom of the cam gear,line it up with the plastic pointer to the left of it. did you get the bottom crank pulley mark set yet?
[Modified by 4gvtec, 8:42 PM 4/19/2002]
Old Apr 19, 2002 | 11:54 AM
W0oT's Avatar
Banned
Default Re: Mini me D16 Timeing Problems please help! (4gvtec)
hrmm everyone else says that mark is suppose to be at 12 o clock and the other 2 should be horizontal w/ the block
also i was cranking it a few hundred times and noticed that it doesn't go to 12 o clock or that little pointer to the bottom left (about 7 or 8 oclock) but it almost lines up w/ the pointer at about 4 oclock. also i noticed when i hooked the timeing light up the marks i believe are at about 3 oclock or so on the crank.
[Modified by Nismo240sx1, 4:01 PM 4/19/2002]
Old Apr 19, 2002 | 11:59 AM
4gvtec's Avatar
no, the bottom mark is at 7 oclock .the other two line up with the head,thats right.
go to your auto parts store and look in the book real quick and youll see.
Old Apr 19, 2002 | 12:28 PM
D-Man's Avatar
100% correct..and once you line up the marks like 4gvtec said,you must also make sure that at the same time either the pointer on the plastic cover is pointing at the white mark,which is TDC or if the cover is off,crankshaft keyway is pointed straight up at 12 o'clock and the dot is lined up with the arrow on oil pump housing.
PS..The red mark in the center of the three grooves of the balancer is 15 degrees BTDC.
Old Apr 19, 2002 | 02:45 PM
4gvtec's Avatar
Default Re: Mini me D16 Timeing Problems please help! (D-Man)
thanks for agreeing with me on this.d-man
Old Apr 19, 2002 | 03:35 PM
W0oT's Avatar
Banned
imed you
can i take off the belt and rotate the cam sprocket 180deg so it's at tdc to fix it. the crank is at tdc and the vertical mark is at 12 oclock instead of 7
lazyxmofo
May 11, 2012 02:11 PM
sonson6
May 10, 2009 03:59 PM
lunch_box_4_life
Jan 9, 2008 09:26 AM
rastaracer
Jul 25, 2004 07:02 AM
W0oT
Apr 19, 2002 03:39 PM
