help timing issues
help timing issues
i just replaced a head gasket on my d16z6 and when i put it back together it ran a little but fell on it's face so my buddy came over and said it was off a tooth which it was so we toke every thing back off and took the timing belt off and moved it a tooth but now it won't start at all so
my question is can someone tell how to set the time so i can make sure that i did it right
Re: help timing issues (lunch_box_4_life)
set top cam gear to up (the maarks on side should be flat), and bottom crank pulley lined up to the mark on the block to the single line on the crank pulley
ok so i blasted that bastard with brake parts cleaner and i found some marks
there is a group of two and a group of three
which one do i want to line up with which part
Modified by lunch_box_4_life at 10:04 AM 1/9/2008
1 Post
Pull the #1 sparkplug and stick a pencil in the hole. Then remove the distributor cap and align rotor to #1 sparkplug wire by turning the crank clock-wise when looking at the pulley.
Then work the crank back and forth til you see the pencil is up the farthest up signaling the the #1 piston is at the top.
Then take a rag and wipe off the pulley.
foolsforever
11
08-09-2018 05:08 PM
96hatchBoy
03-17-2013 09:25 PM
Xemu
28
04-22-2007 01:56 PM
