Does a LSD make car lose horsepower at dyno?
Old Apr 18, 2002 | 11:46 PM
JDMTypeS's Avatar
New User
Default Does a LSD make car lose horsepower at dyno?
Simple...Does a limited slip differential cause car to lose horsepower on the dyno? if so why?
Old Apr 19, 2002 | 12:01 AM
kevie88's Avatar
Default Re: Does a LSD make car lose horsepower at dyno? (JDMTypeS)
No, the dyno is just a big drum that spins both wheels, and an LSD will not come in to play at all.
Old Apr 19, 2002 | 03:09 AM
aklucsarits's Avatar
New User
Yes it does. Depending on the LSD type, the extra drivetrain losses consume about 3-5% of power to the wheels.
Andrew
Old Apr 19, 2002 | 11:35 AM
JDMTypeS's Avatar
New User
I was thinking of getting a quaife LSD. I heard that it will make you lose about 5-6 whp
Old Apr 19, 2002 | 11:42 AM
New User
Yeah that sounds about right... Different LSD types could cause even more drivetrain losses. e.g.: Viscous type LSDs would cause even more drivetrain loss.
But then, who really cares what numbers your car can pull on a dyno if you can't put that power to the ground with your peg-legged stock differential?
Andrew
Old Apr 19, 2002 | 11:59 AM
4bidden's Avatar
Default Re: Does a LSD make car lose horsepower at dyno? (aklucsarits)
are honda lsd's viscous or clutch type?
Old Apr 19, 2002 | 12:41 PM
New User
Default Re: Does a LSD make car lose horsepower at dyno? (4bidden)
I'm pretty sure they are neither. I think the Hondas usually have a gear type LSD. e.g.: The ITR has a planetary gear type LSD, same with the new CL TypeS manual's LSD...
Andrew
Old Apr 19, 2002 | 12:59 PM
Greyout's Avatar
I have a OEM JDM lude LSD - so I'm loosing about 6hp to the wheels with it? or even more?
Old Apr 19, 2002 | 06:44 PM
kevie88's Avatar
Default Re: Does a LSD make car lose horsepower at dyno? (JDM LUDE)
I have NO IDEA how this is going to 'Lose' horsepower on a dyno, a dyno spins both wheels at the same time on a drum, the diff will not come into play at all, how will you be loosing horsepower? I can't see how this is possible, I believe this is misinformation.
As for loosing horsepower in the 'corners', I would say that's BS as well, because the traction you gain from having the LSD will offset any 5-6 horse loss, massively!!
Old Apr 21, 2002 | 02:26 PM
Hi Ho's Avatar
Default Re: Does a LSD make car lose horsepower at dyno? (kevie88)
"a dyno spins both wheels at the same time on a drum"
You've got it backwards, the tires spin the drum.
Michael
Old Apr 21, 2002 | 02:31 PM
kevie88's Avatar
Default Re: Does a LSD make car lose horsepower at dyno? (Hi Ho)
Sorry- thanks Mr.English Professor ! I should lay off the SWED...
lol
[Modified by kevie88, 4:32 PM 4/21/2002]
Old Apr 21, 2002 | 03:45 PM
New User
Again, an LSD results in more parasitic losses to the drivetrain than an open diff. Any time you add additional mechanical parts for the power to be transmitted through in the drivetrain, it will reduce power to the wheels. More gears to turn = more power converted to friction, heat, and noise = less power getting to the wheels on a dyno.
Andrew
Old Apr 21, 2002 | 04:13 PM
Gennady's Avatar
New User
Yes! It works on the same premise as manual hp vs. auto hp. A car with a manual tranny will usually dyno slightly higher numbers than one with an auto because the auto has more moving parts and more places where hp is lost. Basically, the more that is moved, the more hp is lost.
Old Apr 21, 2002 | 05:16 PM
kevie88's Avatar
Default Re: Does a LSD make car lose horsepower at dyno? (Wont be beat)
This argument does not make sense, you need to look into how a differential works. http://www.howstuffworks.com/differential.htm
In a straight line, there is no 'diff' effect, (ie: both axles are turning the same speed) the axle acts as a locked unit and turns as one, Therefore you cannot lose horsepower from it! The only parasitic loss will be from the extra weight of the clutches or gears (at the most 1 or 2 lb) which is located so close to the center of the axle it would barely affect anything at all.
Old Apr 21, 2002 | 05:25 PM
kevie88's Avatar
Also, an LSD unit usually has a smoother housing than an open diff, which would decrease parasitic loss from oil displacement.
Old Apr 21, 2002 | 06:16 PM
bb6h22a's Avatar
Default Honda LSD's
The ITR LSD is a helical gear type. The aftermarket LSD such as the Kazz, Mugen, and Spoon are clutch type and give off the resultant chatter at low speed, also b/c they are clutch type, the LSD's will eventually wear out, or rather the clutch disks will, that is primarily why the OEM LSD's are now helical gear; greater service life w/ minimal maintenance. Honda also used the viscous type LSD's in the JDM XSi Integra's and EF8's.
Hope this all makes sense.
Old Apr 21, 2002 | 06:38 PM
kevie88's Avatar
Default Re: Honda LSD's (bb6h22a)
Honda's H22A factory LSD is a clutch type.
Old Apr 21, 2002 | 06:39 PM
bb6h22a's Avatar
Default That..
..I didn't know. Thanks.
GT30RSX
Mar 1, 2007 03:29 AM
b18c195
May 23, 2004 06:53 AM
Project_SOHC_EX
Oct 2, 2002 02:33 AM
Name
May 13, 2002 02:00 PM
KekeK-18
Oct 22, 2001 01:23 AM
