Bad Valve Guide?
Bad Valve Guide?
Is it possible for a N/A prelude H22a with just i/h/e and VAFC to get/messups a valve guide after 44K miles? No major down shifting or hitting the rev limiter. Do these things go bad after a while?
Re: Bad Valve Guide? (Quaalude)
Ok I took out all my spark plugs and in cylinder #4 the plug was all black with carbon build up really bad. and there was oil all over the plug. What else could be worng? I haven't done a compression test yet. But is there is seal or gasket I could of blown????
Re: Bad Valve Guide? (Sushi X)
do i compression test to see what numbers u get and a leakdown test to see where the culprit is...could be a number of factors and the leakdown test helps u narrow it down
iBrandon
07-31-2006 08:03 AM
