Help idk whats wrong, cant go over 4500rpms at wot???
i have a 94 civic hb ls turbo w/ 450cc inj, t3/t4 turbo, and a chiped comp. 4 some reason my fuel psi is a 69?? dont know y. i do have a stock fuel pump and regulator. can anybody tell me whats goin on with my fuel psi?
what kind of 450cc injectors are they? meter the voltage at your fuel pump. how are you verifying your fuel pressure? what does the "chip" in your ecu do? what are your a/f ratios like? i am assuming rich as hell and you can't make a flame above 4500rpm. what does your timing look like? there are many questions you need to answer before ANYONE can help you. there are many things that can make a car not rev. does the engine rev witout a load?
01PYTypeR#1140
Apr 8, 2007 03:14 PM
