emergency brake adjustment
Old Jul 3, 2006 | 10:58 AM
alex_s817's Avatar
Default emergency brake adjustment
i have searched for this and can find some info but not everything im looking for. i just put new rear calipers, pads, and rotors on both sides. right now only the left side wheel locks when the ebrake is fully engaged. the right side spins freely. i have read that i need to adjust the 12mm bolt underneath the center console, but is there anywhere else that could be adjusted? when looking under the console at the "t" hook-up for the brake lines, the one on the right is about an inch longer causing the "t" to be off-center. thanks for any help
Old Jul 3, 2006 | 11:21 AM
alex_s817's Avatar
Default Re: emergency brake adjustment (alex_s817)
please help! i working on it right now
Old Jul 3, 2006 | 02:57 PM
integralactic's Avatar
just try tightening that nut to make everything even and see how things go from there.
Old Jul 4, 2006 | 08:31 AM
alex_s817's Avatar
Default Re: emergency brake adjustment (integralactic)
when i tighten that nut, everything gets tighter, but the cables are not evenly pulled. no matter how tight i get it, they do not even out.
ShadowDaisy82
Honda Civic (2001 - 2005)
May 9, 2017 01:36 PM
LU
Aug 14, 2008 07:56 AM
roflcopterdown
Oct 13, 2007 01:55 PM
JDM_EH2
May 31, 2007 05:53 AM
Clydsdal
Sep 15, 2003 05:02 AM
