help me install my Konis
Old Apr 18, 2002 | 07:11 PM
Aahj's Avatar
Default help me install my Konis
I am in the middle of installing the front Koni shocks on my CRX using the stock springs. I need to re-use the stock collar that is located on the body of the front shock. It is also used as a bracket to hold the brake lines. I am having a hard time trying to get it off.
I was wondering if anybody had any suggestions on how I could remove the collar from the stock strut.
thanks in advance,
aj
Old Apr 18, 2002 | 07:15 PM
ncrx1's Avatar
Default Re: help me install my Konis (ajn)
hammer the sucker off
Old Apr 18, 2002 | 07:18 PM
Aahj's Avatar
Default Re: help me install my Konis (ncrx1)
yea,
I did this same procedure on my 97 civic and they came right off. This seem to be really hard to get off. I have tryed using a vice to hold the collar, and a rubber mallet to hammer on top of the strut.
thanks in advance,
aj
Old Apr 19, 2002 | 08:42 PM
Aahj's Avatar
has anyone here installed shocks themselves on their CRX?
Old Apr 19, 2002 | 11:24 PM
Ham'ed Hatch
Guest
Posts: n/a
are you talking about the part that sits atop the damper fork when installed?
i didn't know that part came off the stock strut. i thought it was part of the strut.
wierd...
Old Apr 20, 2002 | 01:34 AM
carsaregood's Avatar
i had this same problem... it sucks that koni doesn't provide something to mount the brake lines. I tried getting the spring perch/line mount off the stock shocks.. i didn't get it. i hammered at them, and tried liquid wrench, but to no avail. So... i just have my brake lines zip-tied out of the way... and yes, i've installed shocks on my civic.
[Modified by carsaregood, 10:36 AM 4/20/2002]
Old Apr 20, 2002 | 01:51 AM
REX VT's Avatar
Put the stock shocks in a bench and don't hammer on one side/spot but work around it and use sense instead of force..
It works..
Old Apr 20, 2002 | 03:45 AM
ncrx1's Avatar
Default Re: help me install my Konis (REX VT)
it'll come off with some effort.. but mine came off with a few whacks of the hammer
and yes i've installed my koni yellows with h&r race springs myself
Old Apr 20, 2002 | 05:13 PM
Aahj's Avatar
I will guess I will give it another try.
thanks for the help guys.
aj
Old Apr 20, 2002 | 08:06 PM
Ham'ed Hatch
Guest
Posts: n/a
COOL! we took a few whacks at a stock strut we had laying around, and after a few hits, the ring bracket thing slid right off. keep hitting it!
white90crxhf
Suspension & Brakes
Oct 30, 2007 06:04 PM
vulgar_si
12
Feb 29, 2004 02:17 PM
SOHC_MShue
Aug 28, 2003 09:27 PM
SubPointz
Mar 28, 2003 11:54 AM
OmegaLS
Aug 10, 2002 06:23 AM
