Feedbacks on Ebay crank pulley? And are they interchangeable?
Old Jul 2, 2006 | 08:42 AM
chu77's Avatar
Default Feedbacks on Ebay crank pulley? And are they interchangeable?
Anyone on here tried the crank pulley on ebay? Also are they interchangeable between the h23 and h22? or any honda engine since you need a new belt anyways.
I'm in the market for one, so let me know if you got one for sale too.
Thanks
-Henry
Old Jul 2, 2006 | 08:57 AM
soundbomber's Avatar
Default Re: Feedbacks on Ebay crank pulley? And are they interchangeable? (chu77)
just buy a stock used one. please.
Old Jul 2, 2006 | 11:15 AM
darkspector's Avatar
or ge the UR pulley
Old Jul 2, 2006 | 01:55 PM
darockstar's Avatar
Default Re: (darkspector)
does any1 have a real reason why the ebay 1 would be bad as opposed 2 a ur one that probly cost 100 more
Old Jul 2, 2006 | 04:46 PM
98vtec's Avatar
moderator emeritus
Default Re: (darockstar)
because its ebay......and its a very vital pulley.......
Old Jul 2, 2006 | 10:19 PM
Who knows... if it's built well... what materials they actually use.. the last thing you want is for the whole thing to fall apart while you're whomping on the motor
Old Jul 3, 2006 | 11:00 AM
chitownrida's Avatar
you might not want to risk your motor on an ebay pulley.. the crank is very sensitive to vibrations .. etc
even some people using Ur pulleys have had failures
Old Jul 3, 2006 | 11:22 AM
94Vtecluder's Avatar
Default Re: (chitownrida)
I would not want to use a ebay pulley. I'd be worried about it's design and construction and what material is used. As noted I've seen UR pulley's break (very rarely) but if those break, I definitely wouldn't trust a ebay one. AFAIC the only ebay things that don't matter are intakes and exausts. After that from header's to engine parts themselves can differ greatly in performance, fit and durability when compared to name brand companies. Basically on get ebay intakes and exausts and I'm sure some people would fight me on the exausts too.
Old Jul 3, 2006 | 11:57 AM
i agree with that
there are some things you can buy the generic version of with no real concequences
but the crank pulley for 10$ on ebay is not worth risking your motor
Old Jul 3, 2006 | 12:51 PM
Missing Gears's Avatar
a broken crank or oil pump isnt worth the 1-2 whp that you MIGHT get w/ the ur or any other cheap "power pulley". and yes i have personally seen both happen before, more than once.
if you really need a crank pulley"harmonic balancer" get a new factory pulley. if your making ALOT more power over stock or have drastically changed the internalls of the motor then i would recommend ATI, or FLUIDAMPR.
tundra2000
Jan 11, 2011 02:50 AM
umair
Oct 26, 2007 06:21 PM
sas-Lude
Nov 5, 2006 07:39 PM
OMG WTF
Jan 15, 2006 06:54 PM
som3on3_10
11
Apr 10, 2005 07:10 PM
